rusted out battery tray?
Old Mar 18, 2001 | 05:32 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Does anyone know how or where to get some type of replacement battery tray? Mine on my '82Z28 is completly rusted away. Thanx,ANDYZ28
Old Mar 18, 2001 | 07:46 PM
Jza's Avatar
Jza
A replacement from Classic Industries (1-800-854-1280) is $28.25. PN#G6844 for the right-hand side, and PN#G6845 for the left.
Old Mar 19, 2001 | 04:47 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Thanx,Dude! Is it very hard to install?
Old Mar 19, 2001 | 08:26 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
You can also get it from a local dealer. Same price. Not hard to install, just drill out the old sptowelds and tack weld the new one in place. Clean, prime and paint. Simple.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Mar 19, 2001 | 08:38 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Thanx alot dude! ANDYZ28
82Z 305 w/comp 270 magnum cam,holly.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.poly everything,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
customblackbird
Oct 1, 2015 04:30 PM
Johnoooooo
Sep 22, 2015 08:55 AM
sahlomonic
Sep 20, 2015 07:15 PM
gta892000
Sep 16, 2015 12:37 AM
