Side Molding Installation
Old Sep 26, 2012 | 09:52 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
I just purchased my new side moldings from hawks (The later model wide strip kind) and was wondering what the factory correct way to install them is. Does it run centered directly over top of the body line that goes down the middle of the quarter, door and fender, above it with the bottom edge of the strip along the body line or under with the top edge of the strip along the body line?
Old Sep 26, 2012 | 10:07 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Re: Side Molding Installation
It runs along the body line. There should be two strips of tape running the length of the back of it- they straddle the crease. If you test it with the short piece that goes to the front, you will see what I mean. Just measure the width, divide by2, measure down from the body line and run a piece of tape as a guide, and install. Easy.
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Wesly_66
Aug 26, 2015 09:55 PM
Fronzizzle
Aug 17, 2015 02:52 PM
sonu1975
Aug 11, 2015 08:38 AM
