proper jacking points
Old Sep 23, 2012 | 01:01 PM
mans1's Avatar
Car: pontiac firebird trans am 1984
Engine: 5.0 v8 H.O
Transmission: auto
Axle/Gears: 700R4 auto overdrive
hi what are the proper jacking point for a lift at garage. pics would help as my car will be going in for welding soon enclueing the left floor pan and inner sill i need to know so i can tell him were to put the lift so it does not damage the car eg go throw the car thanks
Old Sep 23, 2012 | 01:56 PM
Nunazet's Avatar
Car: 1985 Trans Am
Engine: Stock 305 converted to carb
Re: proper jacking points
https://www.thirdgen.org/forums/tech...ng-points.html
That link will get you what you need.
just don't let them do this...
Old Sep 23, 2012 | 04:39 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Frame rails are pretty much the only place to lift on a third gen with a shop lift.
Old Sep 23, 2012 | 07:02 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
This. Don't lift it on the pinch welds.
Old Sep 24, 2012 | 09:44 AM
mans1's Avatar
Engine: 5.0 v8 H.O
Transmission: auto
i think the k frame is a little weak we put on axel stands and it was creaking and groning so we put a third stand on the cross member for extra support i am just concerned about the shop lift going threw the frame and totaling the car is any way i can minimize the risk or can strenthen. it is mainly at the front. thanks
Old Sep 24, 2012 | 09:59 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Best way to lift it to do any welding is on a drive on lift so that the unibody doesn't twist or distort in any way for the new pieces to be fitted properly.
Old Sep 24, 2012 | 10:16 AM
stealtht/a's Avatar
The frame rails are by far the strongest point. If you can't lift there, you need a new body.
The k member is a strong point too, but hard to reach with a shop lift.
Old Sep 24, 2012 | 10:49 AM
mans1's Avatar
Engine: 5.0 v8 H.O
Transmission: auto
were are the frame rails and k frame just to be clear at the moment i am jacking up on the a frame on the suspension spring with a trolley jack. but when goes for welding. When done it should be alright but just in case thanks
Old Sep 26, 2012 | 03:52 PM
sleepsinshed's Avatar
Car: 1988 IROC
Axle/Gears: 3:27 9-bolt
I welded some steel plate to the frame rails.
You can see here where previous jacking attempts had crushed the frame rail.
Old Sep 27, 2012 | 06:51 AM
stealtht/a's Avatar
You just have to make sure the jack pad is big enough to span the rail. That kind of damage is caused by a bottle jack or similar with too small a lift point.
Shop lifts usually have large enough pads.
As said before, just make sure they don't lift by the pinch, because that's howit is generally done on Hondas,etc.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Buggy Disaster
Sep 17, 2015 05:12 PM
John in RI
Car Audio
Sep 10, 2015 11:24 PM
