Another Rattle Question
Old Mar 19, 2001 | 06:09 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
I can hear a rattling noise behind the document holder on the passenger side of the dash. It pretty much rattles all the time, but is louder when it is cold inside the car. When you push down on the dashpad on the passenger side, it stops. I have removed the dash pad and driven it a little without it on and it still rattles, so it is nothing with the pad. While I had it off, i tightened down every screw I could find, but the rattle is still there. Has anyone else experienced this problem?
Old Mar 19, 2001 | 10:27 PM
zee28's Avatar
Car: 86 iroc
maybe the heat flap/door under dash?or maybe something is just worked loose,check computer,and all the screws under dash and areas around the noise.
~mike~86 IROC-Z
Old Mar 20, 2001 | 04:19 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I suspect the computer bracket was installed incorrectly. If the probe that sticks out of the case isn't mounted in the rubber socket above correctly it will rattle and move around.
Old Mar 20, 2001 | 09:14 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
What do you have to take apart to get to the computer to see if this is the problem?
Old Mar 25, 2001 | 11:54 PM
lonsal's Avatar
Simple. 7mm or 5/16 socket. Recline the passenger seat all the way back and lay in it with your head on the floor of the passenger side. Remove three screws holding the hush panel (black plastic panel underneath the bottom of the dash) in place. You should see a white plastic case surrounding the aluminum box which contains the ECM. Wiggle it to see if it is indeed causing the noise. If it is, remove the screws holding it in place and drop it down. There is a probe sticking out of it that must be mounted into a rubber lined hole above. It is a pain to get it in there sometimes. Good luck, Lon.
Old Mar 26, 2001 | 07:20 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
Thanks, I'll have to check it out when I have some free time.
Old Mar 26, 2001 | 11:49 PM
nestz28's Avatar
Just a thought, try making sure it is not just the ducts for the side window defroster vents. They were kinda loose on mine and did what you describe. I just shoved some wedges of rubber in the top of them and they have been silent since.
xxx3man`
Sep 23, 2015 10:37 PM
mantaguy
Sep 1, 2015 08:39 PM
aaron7
Aug 26, 2015 09:45 AM
redmaroz
Aug 16, 2015 11:40 PM
mustangman65_79
Aug 8, 2015 12:07 PM
