Overhead console installed. Flashlight restored.
Old Mar 26, 2001 | 01:21 PM
MNformula350's Avatar
Well after having it sitting in the closet on the shelf for almost 2 years i finally installed my overhead console in my T-Top Formula350 Looks great!
The hardest part of the whole thing was putting the Coat hooks back on in the back,who's idea was it to make those so hard anyway? all said and done it took about an hour,that includes the cutting of the holes in the headliner,not too bad of a job. the only real other problem i had was when i went to wire it in i found the the two wires coming up the A pillar on my car were both white instead of white and orange.oh well i just got out the ol test light and got em straight.i aslo installed a rear view mirror with the map lights in it from my old 89 S-10 Blazer.
I also could not get the little removable flashlight to work ,even after i replaced the batteries and bulb,so i took it apart (all the copper pieces out of it,except the one still attatched to the switch) and cleaned them with steel wool,now the flashlight works GREAT!!! just hought id pass that along in case some of you were having the same problem.
By The Way i have removed and replaced headliners in both T-top and Hardtop cars now and have to say that a T-top one is soo much easier due to the more manuverability you get by having the holes for the t's to move around.
84 FIREBIRD-(undergoing rebuild)2.8 V6,5spd,T-Top
90 Formula Modded 350 TPI T-Top
WANTED:82-84 Firebird 2.5 4cyl,4spd-Just Cause
Previous 3rd gen's
83 Trans-Am 305 CFI auto T-TOP
84 Firebird 305 H.O. auto HARDTOP
87 Firebird 2.8 V-6 auto HARDTOP
Old Mar 26, 2001 | 01:33 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
The coat hook holes are a bitch to put back in, I hate dealing with those things.
Old Mar 26, 2001 | 11:18 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Sounds great!
What was the part number for the bulb for the flash light???!! I have been trying to figure that out for a while now...
BTW, I figured out a really easy way to get the coat hooks back in....
Instead of trying to line the screw up first... like I used to do... You put the coat hook where it is supposed to go, then put the screw through it and it screws in perfectly.
I dont know if what I just said made any sense to you, but I cant think of a better way to explain it.
Later!
http://kiztope.50megs.com
92 Rs 3.1/T-5
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14)
"If it can be better than it is, make it so!" Leon Calrinsky (00)
Old Mar 27, 2001 | 06:26 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The flashlights in the overhead console are engineering nightmares. It may work for the present, but within a short time the 'guts' will be fouled again, and you'll be forced to clean them all over again.
JamesC
Lbibb
May 5, 2016 12:00 AM
ndndndnd
Sep 28, 2015 08:00 AM
efiguy
Sep 27, 2015 01:30 PM
MORREALE5
Sep 13, 2015 09:01 PM
scottmoyer
Sep 7, 2015 07:06 PM
