Running a Fuel Pressure Gauge and Line in interior
Old Apr 5, 2001 | 12:26 AM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
whats the easiest way to do it? Should i drill a hole near the pedals, run it up? How many feet of braided line should i need? Its pretty pricey *6 ft are 50 bucks* and the gauge and isolator are 120....so its pretty expensive in the long run. Ideas please
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers (ready to install), Lakewood LCA's, Lakewood Lift bars, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, 4th Gen Seats (not front yet)
" I'd rather run last in a full out race, than to NOT run at all ".
Old Apr 5, 2001 | 01:54 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Do not used a mechanical. One day the gauge many break and you will have fuel in the cabin. Use an electrical one.
Old Apr 5, 2001 | 02:39 PM
theformula's Avatar
He has an isolator to prevent that from happening. The way you described sounds good.
I personally would of gone with the electrical one though. $85 including sender and is just as accurate as a TRUE mechanical.
I don't think it's worh the $120 for a mechanical with isolator. It's not mechanical unless it goes DIRECT from the fuel rail to the gauge.
Old Apr 5, 2001 | 02:49 PM
Spyder's Avatar
Bad idea to put a mechaincal in the int. you can ask a buddy of mine who lost a 69' Chevelle to that.. Autometer has a great kit avalible at checker for around 40.00 with a sensor kit. Works great, I'll see if I can post pictures of mine.
--Spyder--
1992 Camaro RS
LO3, T-56,centerforce clutch, ported and polished heads, Edelbrock Performer Intake, 14X3 Open Element w/ K&N, hiflow cats with two pipes going back, AC delete, SMOG delete, alu drive shaft, 3.73 posi, 170 stat w/ fan switch, STB, Subframe connectors, KYB AGX, Eagle GSC, and poly bushings.
1982 Z-28
327ci CSB, Turbo 350
Old Apr 5, 2001 | 03:50 PM
yea please..maybe you have a part number for me? I cant find one?! I havent bought the gauge yet so if i can find the electric one ill get that.
1989 Firebird
Old Apr 5, 2001 | 04:05 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
I dont known if Summit carries it any more.
Part numbers:
(Intellitronix gauges)
Fuel Pressure gauge: ITC-K704
Sending Unit:ITC-S8434
90 Degree bend: NOS-17535
Braded line: ATM-3227
I bought these on Jan 19th 2001. The inside light it orange to match the other gauges. I also got the Trans Temp in pods.
Old Apr 5, 2001 | 04:07 PM
Theres one in summit from auto meter for 180...i hope thats not it...
1989 Firebird
Old Apr 5, 2001 | 04:56 PM
89GTA5spd's Avatar
Go onto www.autometer.com .. they just released new electrical fuel pressure guages that are a LOT cheaper. ATM-5709 is for the phantom 2 1/16.. it's ~$80 in summit. They aren't on summitracing.com or jegs.com .. but i think they are in some of the summit catalogs. I am putting one in my car very soon.. seems like half the hassle and cost of a mechanical guage.
Old Apr 5, 2001 | 06:44 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
All my cost were:
$39.99 for the fuel gauge $19.99 For the sending unit. $20.00 for the braded hose. $7.00 for the 90 Degree. ~$100
Old Apr 5, 2001 | 10:03 PM
theformula's Avatar
DO yourself a favor and stay away from Intellitronix,cyberdyne, and another brand i cant remember. They are all the same brand. They SUCK. I had 1 fuel pressure gauge and 1 air/fuel ratio and they BOTH BROKE IN A MONTH. I returned them for autometers. No problems at all and it looks better. Like I said BEFORE. AUTOMETER MAKES AN ELECTRICAL FP GAUGE WITH SENDER FOR $84.95
Old Apr 5, 2001 | 10:11 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Mine been fine since I installed it. No problems.
Old Apr 7, 2001 | 02:39 AM
Jza's Avatar
Jza
I have a total of 9 Intellitronix gauges if you include my dash, and they've all been problem-free and accurate going on 1 and a half years now. Same with my old Cyberdyne dash. And they're not the same brand.
And I got an AutoMeter A/F gauge a while back and it worked fine for all of two weeks before it crapped out and I had to send it back. But I don't dog AutoMeter based on that one experience.
But I definitely agree on going with the electric over the mechanical.
specialized
Jun 18, 2022 09:26 AM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
Kaweh
Aug 9, 2015 02:54 PM
