Center console removal
Old Apr 7, 2001 | 02:40 PM
MY87GTA's Avatar
I bought a Ripper Shifter for my car but i can't get the center console out, i have a 87 GTA. Any help will be much appreciated.
Old Apr 7, 2001 | 04:09 PM
Camaro_hunter_d's Avatar
the upper console is easily removed. take off the top trim peices and take ut the center console storage to get to the bolts that hold the upper cover down. when you remove the shifter plate you should be able to see the forwad retaining bolts. take them out and it should come off after you take the screw out of the e brake handle.
Old Jun 17, 2005 | 05:15 PM
berly83's Avatar
Car: 83 Berlinetta
Transmission: 5sp
How do u remove the center console storage compartment. That seems to be where everything is getting held up on mine. Ive taken out every screw I could find. Any tips or ideas anyone?
Old Jun 17, 2005 | 07:14 PM
shipfitter_sjd's Avatar
Car: 1992 Camaro RS Convertible & 1983 P
Engine: 305 TBI & 305 4 BBL & 4.7 liter
Transmission: Auto & Auto & 5 Speed Manual
Me Too.......
.......I am interested in this topic as well. If the weather ever improves, gets over 50 and quits raining for weeks on end, I have a new carpet to install. Of course the old one has to come out as well.
Helpful hints, anyone?
Old Jun 18, 2005 | 03:40 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
a 7mm bolt on each side next to the stereo, take the torx screws out of the console. Remove Shift ****. Take out the phillips screw from the E-Brake handle. Should reveal i believe 2 10mm that have to be taken out to take out the upper console, also 2 in the bottom of console and 2 under console lid latch. upper console comes off. Now theres 4 i believe 10mm bolts holding the bottom console in. I may have forgotten something, as im doing it from memory
Old Jun 18, 2005 | 10:44 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
There are 4 bolts that hold in an '87 Firebird console. Two in the rear of the glove box compartment, and 2 under the shift plate right ahead of the glove box part. You have to remove the 2 screws in the glove box part to remove the shift plate first.
I believe some cars might have had a 5th bolt up front under the ash tray area, but you can see that once the shift plate is off.
Does this help?
Old Jun 18, 2005 | 11:29 AM
berly83's Avatar
Car: 83 Berlinetta
Transmission: 5sp
my problem was that the owner before me decided to line the bottom of the storage space in my console with carpet.
After i found the two screws underneath removal was a piece of cake.
Old Jun 24, 2005 | 04:17 PM
I finally did it!
Well today was the day.......no rain, temps are over 50 and I skipped work (as is my right.....thanks, local 6).
Everything you guys said was right on and was relatively painless. The only thing I would add to the narrative is unbolting the emergency brake assembly so that the console (upper and lower) slides out easily without bending or flexing.
Now to clean everything up and start working on the install.
Thanks again!
Steve
PS: I would like to add that there are a lot of good folks on this board, with one or two notable exceptions. It certainly is educational AND enjoyable!
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Night rider327
Sep 2, 2015 04:17 AM
DonW
Aug 24, 2015 08:24 PM
Firebird sweden
Aug 16, 2015 05:02 PM
