A pillar removal
Old Apr 7, 2001 | 03:28 PM
DSouthern's Avatar
A pillar removal
How is the A pillar removed?
Do you just ply it loose?
Any special tools required?
Don't know if they are all the same, I have an 87 GTA.
Old Apr 7, 2001 | 04:01 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
why in the world do you want to remove the A pillar? are you talking about the trim piece inside the car or the actual pillar itself. i dont think you can remove it without taking out the winshield, cutting it out of the roof and where it goes into the cowl.
Old Apr 7, 2001 | 04:06 PM
Camaro_hunter_d's Avatar
the a pillar interior peice come out by just pulling on it. It has the same plastic plugs that hole on the door panel...theres some useful info for ya
Old Apr 7, 2001 | 04:12 PM
Todd 92 Z's Avatar
I'm sure he's talking about the trim. If you have a T-Top car like mine, there are screws at the top of the trim then the rest is held in by plastic fasteners that you CAREFULLY pry off! The fasteners and the trim that holds them is pretty weak so try to be carefull but you will probably break one or two of them getting them off but you should still be able to get them back on.
Old Apr 7, 2001 | 04:16 PM
DSouthern's Avatar
Hey, thanks guys.
Yes, I should have said A pillar trim.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Fox118
Sep 12, 2015 09:29 PM
Stroopwafel
Sep 11, 2015 06:38 AM
