my 91 trunk will not close
Old Nov 30, 2012 | 08:37 AM
z91bowtie1's Avatar
Car: 91 Z28 convertible
Engine: 96 LT1 5.7
Transmission: t5 5speed
Axle/Gears: 3.73 gears
hi all i have a problem with the trunk on my convertible camaro. the other day i was removing the subs out of my car and when i shut the trunk it locked but did not go down. i checked the fuse and it was good. so i took the trunk lock assembly off and took it apart lowered it back down lubed it up and put it back together. i checked the motor by taking two wires and hooked it up to the battery. it turned in both directions so the motor is good . so i reinstalled it back in the car as soon as i hooked the connecters on the motor it turned on and went back to the up position and will not go down again. does anyone know if its the relay a wire or the black up and down switch. any help thanks
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Pac J
May 17, 2020 10:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
