Light in Rear View Mirror
Old Apr 29, 2001 | 08:46 PM
Mike92RS's Avatar
I have a 92 RS with the rear view mirror containing map lights. Just to the left of the right map light under the mirror is a little diagonal slot, which appears to be another light that shines down around the ash tray and shifter. I believe I have seen it come on once or twice while driving, but I have not been able to find anything that triggers it. Does anybody know what this light is for, and what triggers it?
- Mike
Old Apr 29, 2001 | 09:18 PM
twells's Avatar
Car: 1999 Tahoe LT 4x4
Engine: 5.7 Vortech 350
Transmission: 4L80E
I have the same light but mine stays on all of the time day and night, every time the car is on! I would like to know what it is also.
Twells
1992 R.S. 25th Anniversary
* Borla
* Open Element
* Hypertech Chip
* Smog pump delete
Thats all for now!!
Old Apr 29, 2001 | 10:17 PM
RARE-ROC-Z's Avatar
as you described it.. is what it is for.
IT SHINES DOWN ON THE ASHTRAY AND SHIFTER.
that is what it is there for.
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 7.5" 10 Bolt 3.23gears
Bright Red Hardtop/ Grey Custom Interior
5,507 IROC's Hardtops/Ttops; 2,415 5.7L IROC's Produced in 1990
DAILY DRIVER: 1991 S10 2.5L/5SPD WITH CAMARO RIMS
Old Apr 29, 2001 | 10:26 PM
PhantomTPI's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
My 98 C5 has the same thing in the same area.
1986 WS6-Equipped 5.0 TPI Trans Am
Random Tech High-Flow Cat
Two Chamber Flowmaster Muffler
Megs Custom 4.5" Stainless Steel Rolled Tips
1999 Grand Am GT In-Dash CD Player w/Equalizer(fits like '86 original)
5% Tint On Rear, 35% On Sides
http://www.pitt.edu/~zyhst/trans86/
OTHER RIDE:
1998 C5 6Spd. Corvette Coupe
Silver w/Gray Leather Int.
12/14 Options
Stock(for now)
Best 1/4th: 13.5 @ 104.4MPH
Old May 2, 2001 | 07:32 AM
Mike92RS's Avatar
But do you know what is supposed to trigger it?
Old May 2, 2001 | 08:43 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Parking lights or headlights?
Maybe you have a bad connection and the bulb is bad or wiring..
Old May 2, 2001 | 08:55 AM
Stoopalini's Avatar
The parking lights trigger mine. If my lights are off, it is too. As soon as I pull the light switch out into the 1st position (parking lamps) it comes on.
Sounds like the bulb is loose or something. Take it apart and clean the bulb contacts up.
Thomas.
1992 RS Camaro - Red
305-TBI/5 Speed Manual- centerforge clutch/3.08 geared rear
1.6 Roller Rockers and Cam / Adjustable Fuel Regulator with high flow pump / Open Air K&N Filter / TBI Spacer / ADS Super Chip & custom burned Off-Road Only chip
Headers - Cat Back system - Flow Master - dual chrome tips
adjustable Coni shocks & struts
jaridjohn
Jul 8, 2024 03:49 PM
sailtexas186548
Aug 26, 2015 03:32 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
