Fender tab rot repair
Old Dec 17, 2012 | 10:31 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Ok i got a question im wondering if i cut out the fender tab rot / rocker panel do i have to worry about the car twisting im kinda warry about cutting it out since i saw on here that i might have the make a support which i dont have time an money for. I have the front floor section just before the seat to the foot board cut out to replace with new pieces i got off a donor car if someone could help out letting me know how to make the cut with out the twisting of the car thanks in advance
Old Dec 19, 2012 | 06:31 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Fender tab rot repair
Without seeing exactly what you are cutting out I can't say for sure but I would support it anyway just to be sure it doesn't shift. All you really need to do is support the frame rail under the spot you are working, gravity pulling the center of the car down is the only force working against you. No expense really, just a jack stand or some blocks will do.
Old Dec 28, 2012 | 01:06 AM
StripedZ28's Avatar
Car: 1985 Z28 Camaro
Engine: 390CI SBC Stroker
Axle/Gears: 4.10 (Ford 9")
need pictures
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
jovibuilt
Oct 18, 2015 08:12 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
