interior paint for arm rest
Old May 7, 2001 | 08:41 PM
chrisandkristin's Avatar
i bought some arm rest that are gray the thing is that my interior camel......will interior paint work ...... thanks
Old May 7, 2001 | 09:04 PM
Belker's Avatar
I would guess the paint would wear off easily (but I don't really know). How about re-covering it with leather, vinyle, tweed, ect. ?
Old May 8, 2001 | 01:15 AM
Omar's Avatar
I used the vinyl dye from Classic Industries to paint my arm rests from tan to carmine red. It worked great.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old May 8, 2001 | 05:11 PM
86ZRICHIE's Avatar
if you prep it right it shouldn't be a problem. clean it well, run a tack cloth over it, then use an adhesion promoter on the surface and paint...unless you use dye, not sure if it works different or not. regardless, prep is the key
Old May 8, 2001 | 07:18 PM
Nightcruzer's Avatar
Car: Trans Am
Prep is the key. It absolutely has to be clean, clean, clean. I used VHT penetrating color dye from Summit. No problems. Did I mention the part has to be clean? A good scubbing with formula 409, a good rinse, a second good scrubbing with 409 and a good rinse all the while holding the piece with latex gloves or put a dowel through one of the screw holes to hold it. The oil from your finger print,will prevent dye from sticking. Then the part has to be Absolutely dry! use a hair dryer or heat gun, but don't burn the vinyl.
Old May 9, 2001 | 05:24 PM
91DropTopTA's Avatar
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
I've used paint and dye before and I think the dye works better. Paint has a tendency to peel, and if it's scratched the old color shows through.
Old May 10, 2001 | 09:50 AM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
I bought some dye from autozone, changed from white to black, I just cleaned the armrest off with windex and used light coats, actually looks better than the other side! May have to do that sometime.
1991 Chevy truck 5.7 engine
Competition Cam 454 lift
Edelbrock Valve Springs
Holley Red Electic Fuel Pump
Eldelbrock Performer RPM Intake
Holley 750 Double Pumper
68 jets front 74 jets rear
Turbo 350 transmission
B&M shift kit
Flowmaster exhaust
No emissions or computer
Grant steering wheel
http://www.fbody.com/members/Camrs89/
Vintageracer
Jan 10, 2020 05:33 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
3rdgenparts
Aug 8, 2015 07:09 PM
