How do I remove my wipers?
Old May 11, 2001 | 11:59 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I know it's probably a dumb question, but I figured I'd ask instead of just trying to figure it out and breaking something. Today I sanded and painted the strip around my hatch and while I was looking at my car, I saw that my wipers look like hell. The paint has come off somehow and I want to take them off and repaint them black again. I'm not talking about blades, I want the whole thing off. How do I remove it? Thanks.
1992 Camaro RS
305ci automatic, all stock til I get some cash.
My 1992 RS
Old May 11, 2001 | 12:04 PM
CamaroZ_85's Avatar
i took them off another gm once, but i'm not sure that it's the same on out cars. check at the base of the arm, to see if there is a little tab at the bottom. if so, push it in or pull it out, whichever way it goes, and the arm should slide off. just make sure you note the position on it, because it's splined and you'll have to line it up again
85 Z28- 350, Comp 262, Edelbrock Performer intake, Edelbrock 600 cfm carb and Edelbrock cat back, Summit headers and vette servo
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
Old May 11, 2001 | 01:54 PM
cvpde37's Avatar
Just had mine off yesterday. There is a small tab that you pull out, then push down slightly at the hinged part of the wiper and then lift up at the very bottom. It's very easy.
1984 Z28 350
Never argue with an idiot, they'll just bring you down to their level and beat you with experience
My Web Page
Old May 11, 2001 | 02:56 PM
Car: 1989 IROC-Z
Engine: 383 stroker
I found the tab. It was hard to pull out but I managed with some pliers. Is it supposed to be that hard to pull? It only comes out VERY slightly. If I lift the wiper, I can pull it out a little more. Then I try to pull it off and it doesnt come off. Is the tab supposed to come all the way off? I appreciate the help
1992 Camaro RS
My 1992 RS
Old May 12, 2001 | 01:39 AM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Those damn tabs freeze up all the time. I cut my finger on the ***** once. Spray it w/ some WD and/or put some anti-seize on it..... not that you are removing your wipers alot
Michael Graeber
My Garage
1)83 Z-28 T-Top: Full cage, 9" w/ lad.bars, Midwest Engine Tech 406sbc,Strip Dominator, 1000-CFM Demon Carb, Phase VI Chevy Bowtie Heads 2.05/1.60, .630" Crower roller set-up, 1 3/4 coated Hookers 3" true dual exhaust th400, fuel cell & still not running
2)89 Formula WS-6 305 TPI Auto Daily Driver: minor motor mods, more suspension stuff. MODS
Old May 12, 2001 | 06:43 AM
cvpde37's Avatar
No, the tab does not come all the way off. It just slides out a little ways and then lift at the lowest part of the wiper.
wigmobile
Feb 26, 2025 02:56 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Stroopwafel
Sep 11, 2015 06:38 AM
adelane
Sep 9, 2015 08:51 PM
scottmoyer
Sep 7, 2015 07:06 PM
