'86-'87 wiper motor retrofitt onto an'82?
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I have had quite a few problems with the windshield washer portion of my wiper motor on my '82 Z28. I have agood motor assy from an '86. I want to install it on my '82. But I can not seem to figure out how to make it work properly (the wiring is different). Has anyone done this conversion? How do I convert the wiring?
82Z 305 w/comp 270 magnum cam,Edelbrock Performer RPM,Holly 1850-4,serpentine belt drive.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.poly everything,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The 84 and newer units have a different bolt pattern and won't mount to the firewall, plus the shape of the firewall itself changed in that area between the 83 and 84 model years, there isn't room to mount the longer motor assembly.
Your best bet would be to mount the pump seperately on the firewall or inner fender, and run the power wires and fluid hoses to it.
Pete
Pete's Place
HiOutput Tech Page
83 SC
originally a V6...now
206+k mile LG4/5-speed
14.935@94.14
Pete
Pete's Place
HiOutput Tech Page
83 SC
14.935@94.14
