Center Console Button
Old May 13, 2001 | 04:32 PM
Jiffy's Avatar
Does anyone know where I can find a center console button spring...the spring thing broke so I took out the button. Any ideas?
Old May 13, 2001 | 07:34 PM
jobryan26's Avatar
Are you talking about the Power Window Switch? Why not just get a new one?
<marquee>'87 Trans Am:
(Engine)305 TPI,180 Degree Thermostat,JET Fan Switch,TB Bypass,Accel 300+ 8.8 Racing Wires,Accel Super Coil,Bosch Platinium Plugs,Custom Ram Air with K&N,Removed Emissions Equipment & Cat.(Stereo)Full Kenwood Excelon System Member at kyfbodies.org
</marquee>
[This message has been edited by jobryan26 (edited May 13, 2001).]
Old May 13, 2001 | 07:54 PM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
new or used switches run less than 8 bucks...
Duffster (age 32)
BEAT DOWN HARD 88' Camaro Sport Coupe,
1978 Caprice Classic 305 motor havin'(WITH NO COMPUTER),Torker II intake, Edelbrock 1406,600cfm w/vacuum secondaries,Accel HEI Supercoil/Cap/Rotor Sparkin',84' POS 700R4 Tranny usin', 84' Z-28 Nose clip wearin',
84' Z-28 Hood covered,
AND THE TIRES:
245/60-16 Firehawk SS20 on Firbird rim(1-passenger rear),
235/55-15 BF Goodrich's on CompTA's on Z28 rims(2-on front),
235/60-16 Pirelli P600 w/a curb check or 3 also on Firebird rim(1-drivers rear),
REAR HATCH MASTER OF ALL!!!
DuffsterCamaro@HOME.COM
Owner of the Camaro 0 out of 10 Third-genners approve of, no longer part of the non-existent Iowa crew.
Old May 13, 2001 | 08:28 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
You're talking about the release for the console lid, aren't you? If you ask GM, they'll sell you a whole lid assy. If you ask a bone yard, you can get one... Try thirdgenparts - Jim's put those on his auctions before...
KAM
Old May 13, 2001 | 10:37 PM
Belker's Avatar
The factory spring is a curved piece of metal that normally holds the button in the out position and flexes when you push in the button. Mine also broke.
I tried to make another one from a piece of metal I cut from a hose clamp. It didn't work and I'd suggest not trying it yourself.
Why does it have to be this type of spring? It doesn't. Just use a regular coil spring.
Find one that is a small enough diameter to fit in the space and strong enough to hold out the button. The spring should ideally be one that is meant to be compressed (instead of stretched) or you could use the other kind and just stretch it out so that it is relaxed in the uncompressed state. Then glue one end of the spring to either the button or the plastic inside part of the lid. Reassemble and your problem is fixed.
I did this about 9 months ago and it is still working fine. No more rattling button.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Lbibb
May 5, 2016 12:00 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
ndndndnd
Sep 28, 2015 08:00 AM
