Gauge Needles...remove them?
Old May 7, 2001 | 02:12 PM
Ryan Theroff's Avatar
I have a 88 Camaro gauge cluster and I can't seem to get the needles off. Is there a trick to this or are they just stuck on? I dont want to break or bend them so I thought Id ask the correct way to remove them. Thanks guys
Ryan
Old May 7, 2001 | 10:34 PM
zee28's Avatar
Car: 86 iroc
they just pull off.the ones o my 86 were stuck bad and I broke 2.pry carefully on the back of the little circle as close to the needle shaft as possible.I broke part of the circle so i just glued it back when I put them back together.
~mike~86 IROC-Z
Old May 16, 2001 | 07:53 AM
USA-1's Avatar
Car: 1987 Iroc Z "Classic Roc"
Engine: 5.7 350
I broke mine too but I didn't care because I was buying all new. Here's a helpful hint - use a fork to lift the needles. Seriously! The prongs from the fork put equal pressure on each side of the round piece holding the needle in place. I didn't think of this until after I broke the first one. Good luck!
Old May 16, 2001 | 09:57 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Be careful to mark where all the needles point with your ignition on! I made this mistake, and my Tach needle is waaaaayyy off! And its a pain to get right. Only take off the needles if you have to.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
