Raise Headlights Manually Firebird
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
Hi,
To raise the headlights manually there is a **** beside each light. I can't get this to work. I remember trying a few years back and couldn't get anything to happen. The headlights did work fine opening and closing but couldn't get them to operate manually. Now I have the car disassembled and am putting it back together again I would like to get to the bottom of this. My first question is do I just twist the **** in the direction shown and should something happen. Does the battery need to be connected or should they raise by twisting the **** with no power.
Thanks.
Thanks.
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Re: Raise Headlights Manually Firebird
When I got my car the headlights did not come up and would not come up manually. I read on here about the 3 puck type things in the headlight motor gears that turn to dust. Well I got the repair kit from TDS and installed them. My headlights work great and i can manually open them as well with some turns of the ****. It's odd to me that your lights popped up on their own, but not with the manual ****. No the battery does not need to me hooked up, I have manually cranked headlights up on junkyead cars with no battery.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
You have to disconnect the power first,stick a ballpoint pen in the **** of the actuator and rotate in a clockwise direction until you here a click.
Engine: LB9/3.1
Oh sorry I did not see that the OP's car is an 82. My 87 headlights will come up manually with the power hooked up.
Engine: 2.8 V6
I have seen this mentioned in the Haynes manual but doesn't make sense to me. There are two holes in the **** on the actuator but doesn't look like anything goes into them. Maybe they changed the setup after 82.
Engine: 2.8 V6
Thanks.
Engine: 5.0 EFI
Engine: 5.0 EFI
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
A lot of the PLASTIC ***** are stripped out over time and by forcing them to work. Take the ***** off of the shafts and turn the shafts with pliers until the headlight is all the way up. There is no lock on the shaft that needs to be pressed with a pen to unlock the mechanism.
Engine: LB9/3.1
Engine: 2.8 V6
Thanks.
1992 Trans Am
May 10, 2023 07:19 PM
toronto formula
Nov 10, 2015 06:17 AM
