'82 Window Sprayers Issue
Old Feb 9, 2013 | 04:57 PM
McChoka's Avatar
Car: '82 Z28
Transmission: TH-350
Axle/Gears: Posi
From the looks of it, the hoses are hooked up and clean, the pump is hooked up, and the reservoir is full. But all I can get to happen is the wipers go when I try to kick the sprayers on. I don't know if its a fuse or something else simple but it beats me. Thanks in advance.
Old Feb 9, 2013 | 06:21 PM
rickwise's Avatar
Car: 1986 camaro
Transmission: a.t.
Re: '82 Window Sprayers Issue
Are you sure the pump is working? Can you hear it running?
Old Feb 9, 2013 | 06:26 PM
McChoka's Avatar
Car: '82 Z28
Axle/Gears: Posi
It sounds like its trying to work, but then again I could be wrong.
Old Feb 9, 2013 | 06:50 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
kinda got the same problem but mine is a pump from an 85 transplanted onto my 87. I can here the pump working. But no spray, just to be sure which way do the hose connect? I have the hose from the bottle on the bottom fixture and the top one goes to the wipers right?
Old Feb 9, 2013 | 06:55 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
For what it's worth, the pump to my rear wiper requires priming from time to time.
JamesC
Old Feb 9, 2013 | 06:58 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
how do you prime the washer pump?
Old Feb 9, 2013 | 07:36 PM
McChoka's Avatar
Car: '82 Z28
Axle/Gears: Posi
My pump hums and all the hoses are intact and hooked up. So I'm gonna go with the notion that I'll have to prime mine as well.
Old Feb 11, 2013 | 05:55 AM
TPeye's Avatar
Car: 1992 Camaro Z28
Engine: 350ci
What is the temperature by you? The fluid likes to freeze in the lines during the winter. The pump is pumping against the frozen part so nothing comes out.
Old Feb 11, 2013 | 06:24 AM
JamesC's Avatar
Windshield wiper fluid?
JamesC
Old Feb 11, 2013 | 08:12 AM
McChoka's Avatar
Car: '82 Z28
Axle/Gears: Posi
When it was down below zero, it didn't work but the other cars' did. Now its above 40 and the sprayers still don't work. I'm guessing my pump is bad or I lost the prime when the car was sitting.
Old Feb 23, 2013 | 09:49 PM
cwt's Avatar
cwt
I have the same problem. Pump goes but nothing comes out.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
evan555222
Sep 20, 2016 02:51 AM
pfsteichen
Feb 9, 2016 06:59 PM
dbrochard
Aug 30, 2015 05:56 PM
