-={ Sick of getting my neck cut }=-
Old Jun 12, 2001 | 02:21 PM
o2sk8's Avatar
Car: '87 IROC
Engine: Near Stock 350
Transmission: Stock 700R4
These are the seats I have in my car now:
I also have the little seat belt holders that are normally attached to the stock headrest attached to them, the problem is I can't get them to stay on because the screws don't hold well in the foam headrest. Did anyone else have this problem and find a solution to it because you can only have the damn seatbelt wap you in the face so many times before it becomes a problem.
http://www.o2sk8.com
Old Jun 12, 2001 | 09:43 PM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
Yeah, I gots those. Same problem, too. I think that there are a couple of anchors inside the headrest that move around with time. It's kind of similar to the coat hook problem in the back, you just have to keep trying until you find the right hole. I guess that can be said about a lot of things in life.
Old Jun 15, 2001 | 01:56 PM
o2sk8's Avatar
Car: '87 IROC
Ha ha ha, good form Hummer
Old Jun 15, 2001 | 06:00 PM
Saywhut's Avatar
You can use a scratch awl to locate the hole in the metal,(thru the seatbelt guide),then insert the screw. If the screw dosen't hold, which is common, simply use a slightly bigger screw. Same for the coathooks.
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
gord327
Oct 3, 2015 01:25 PM
Linson
Oct 1, 2015 09:50 PM
ndndndnd
Sep 28, 2015 08:00 AM
