With or without hatch motor?
Car: 1986 Camaro
Engine: 350 - carb
Axle/Gears: Stock
Seems like my car is a base model. Manual windows, locks, no extra light in hatch area. I see no motor around the hatch latch. However I'm getting exhaust fumes in the car and im guessing it's from the rear where e duals exit. There is something right next to the hatch latch - a sensor? Should it have a latch motor?
Car: 1984 T/A
Engine: LQ4
Re: With or without hatch motor?
if there are fumes entering the car than you have a leak. you hatch could be misaligned or not mating properly with the weatherstripping surfaces. also check the spare tire area for holes.
Car: 1986 Camaro
Engine: 350 - carb
Axle/Gears: Stock
Just had exhaust checked out and gaskets at y-pipe changed. Still have exhaust smell in cab, but only with windows part way down. I added extra stripping to seal under the hatch, no difference. Retorqued header bolts. Put in pull down motor. Very little if anything changed. Even set it to max ac - no difference.
Car has those bow tie exhaust tips coming straight out of the back. Would that cause exhaust to get sucked into the cab?
Axle/Gears: 3.45, 3.27, 3.27
1986 model year cars did have a motorized hatch pull-down unit standard.
Lon
Lon
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
The connector for the third brake light?
