Painting interior panels?
Old Jun 15, 2001 | 07:50 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
I thought that a few of the plastic interior pieces had bee replaced, but noticed that the paint just came off them. I want to repaint them, but I'm not sure how. Can I paint them the same way the bumper covers are painted? I don't want this to be a project I will have to do again. If anyone has done this before, let me know.
Old Jun 15, 2001 | 10:13 PM
350IROCconv's Avatar
If you go to a local automotive paint supplier they carry a spray can interior dye for about 8 bucks that is the factory colors exactly, the brand is SEM. That is the only brand that I have found to match the factory colors exactly. Clean the panels with laquer thinner or Acetone first, though, so they won't fisheye. Once they're cleaned the dye won't come off unless stripped, it's great stuff.
Old Jun 17, 2001 | 02:48 AM
86ZRICHIE's Avatar
som adhesion promter before you apply the paint will help too, I use Kleen-Strip's Bulldog adhesion promoter, you'll probably find it at the same place as the SEM stuff
[This message has been edited by 86ZRICHIE (edited June 17, 2001).]
Old Jun 17, 2001 | 12:20 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Acetone would be a good choice. Use EXTREME caution with laquer thinner. If you use it keep the rag real wet and move across your surfaces real fast. Laquer thinner will melt plastic in a heartbeat. Don't lay the rag on any of your pieces either.
Just use the Acetone or surface prep made for the job......it ain't worth the risk.
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
neekolzun
Aug 24, 2015 04:59 PM
AkDrifted
Aug 17, 2015 07:45 PM
Exxon Limited
Aug 9, 2015 08:13 PM
