Installing Headliner this weekend
Old Jun 21, 2001 | 05:25 PM
mcconahay37's Avatar
My headliner started fall in on me Monday, so I'm going to replace it this weekend. I already have the headliner material and the 3M spray. Are there any tricks you can give me to make this job go as smoothly as possible? Best way to remove old foam off headliner base? Any tricky trim pieces to remove, etc?
82 Camaro:
350, Erson cam, ported heads, Crane Hi-6 ignition, Accel supercoil, Comp Cams 1.6:1 rocker arms, TH350 tranny with 2500 stall.
SLP 1 3/4" headers
Old Jun 21, 2001 | 05:47 PM
GndPrx's Avatar
When I pulled my liner off, I found a nice medium stiffness scrub brush to be the best way to clean off the old foam. Just scraped it right off with no effort.
Carl
CarAudio Resources
Old Jun 21, 2001 | 08:18 PM
Jza's Avatar
Jza
And get it all off, don't get lazy or in a hurry. If you don't it'll "bubble" up and you'll be back where you started.
Old Jun 21, 2001 | 11:26 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
Use a wire brush, like the one you would use to scrape paint off a board. It will take all the old foam off and give you a nice canvass to work with. Good call on the 3M glue. I tried to save a buck and had bought some cheap stuff. "I wonder why it fell down the next day?" Oh well, lessons learned...
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Golfvette
Aug 24, 2015 06:35 PM
TheJoeY88
Aug 13, 2015 06:51 PM
