are SFC must-have?
Car: Pontiac Trans Am GTA
Transmission: th700
are SFC must-have?
moderators can move this topic to better place if its in wrong territory.
but to the point. here in finland we have lot of discussion about the sub frame connectors. i dont have those and im more like sunday-cruiser-type-of-guy
and i dont se why have to get them. but most here says its the first modification to 3gen what you have to do.
what do you think? i know that hardtops might get some cracks on the roof if theres no SFC.. car is quite "saggy". like american cars usually are. i like soft rides
and i dont se why have to get them. but most here says its the first modification to 3gen what you have to do.what do you think? i know that hardtops might get some cracks on the roof if theres no SFC.. car is quite "saggy". like american cars usually are. i like soft rides
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: are SFC must-have?
If you're just cruising for the most part then they're not needed. Use the money for gas. Or a date. If you want to go fast on the bends that's a whole other story.
Transmission: th700
yeah, thats what i think too.. gas here is really expensive.. over 1.7 per litre. thats something like over $8 per gallon.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Adding SFCs helps correct a factory design flaw with these cars,have had SFCs on mine since '94-like car better with the SFCs,much more rigid even with 250,000+mi now
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
put them in no matter what.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
My car hasn't been abused. Even so, stress cracks developed behind the windows. If normal driving can cause such issues, reason dictates that shoring up the unibody's structural integrity is wise. That said, since you're the caretaker of your car, do as you see best.
JamesC
JamesC
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Yes . Highly reccomended no matter what type of driving you do
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Anyone who has ever installed them, and drove the car before and after will tell you yes.
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Which is great if you've got money for SFCs AND beer! I'm trying to drink less so I can get the SFCs (I auto-x) but it's a sad state of affairs.
Car: 1986 Firebird
Engine: 6.0L LSX
You say you like a soft ride and equate that to a "saggy" ride. SFC's have nothing to do with a "soft ride". If you care at all about your car and want it to stay structurally intact, you will take the time to install SFC's.
If your car has even a half way decent paint job it will save it from all the stress cracks around the rear top of the roof. This in time opens your car up to corrosion issues....you get the idea.
In conclusion, the SFC's are "not needed" but if you care an ounce about your car you WILL install them.
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
OP If I had a GTA and it was original then no leave them off. But if it's not original and you don't care if it is and you auto-x then yes. I went on top with my SFCs. 8 point cage welded directly to the front and rear subframes. Took out the back seat completely as they are the most uncomfortable things to sit in since the horse and buggy days. Watching amish maffia and I believe their buggies had better, more comfortable seats. More room for sure!
Transmission: th700
actually it got repainted last summer.. okay maybe i'll save some money for the sfc's..... i wish the desing would be better
You can just buy 2"x1 1/2" rectangle tubing that's 11ga and do the outers, weld along the pinch every 6" and connect the rear and front unibody frame section and be done with it for around $30... granite you have the tools and skill... If your like me you build yours over kill...
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Thats one SHARP ride Fueled Soul. I like that dual exhaust.Did you do that yourself also? Can't do that to mine, exhaust that is. Drags all the time with the factory exhaust. Just sits a little too low.
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
It's not a GO FAST mod but it's definately worthwhile. I like the kind that tie into the lower control arms in the rear. Box those with steel too if they are still stock pieces. My sfc's are welded to my rollbar also, very stiff setup.
Car: 82 Z28
Transmission: TH350 for now
If money is tight SFC for our cars are pretty simple you can just by the steel and make them. When you think about it anyone with the skill set to weld the ones you buy in should also be able to make a set. If they can't, well they shouldn't be welding!
I do not see why this is more than a ~$50 exercise.
Car: 1984 Chevy Camaro Z28
Engine: L69 5.0L H.O.
Transmission: T-5 5 Speed
Axle/Gears: 3.73:1 Limited Slip Posi
that's some nice work FueledSoul! I want to twist this question a bit I know of the benefits to SFC but what if you have a nice low mileage original car that still feels nice and stiff. would you still install SFC's? if so would you put boltons or welded?
Car: '82 z28
Engine: L83 5.7
For a low mileage original that gets driven only on nice days and does not get thrashed on,SFCs not really needed until flex starts to creep in later down the road.When i bought my '82 hardtop,8yrs old and ~85,000 mi,it was pretty tight yet except a little"hatch rattle"here and there.After several years of daily driving strough subzero winters and all,started to notice flex creeping in and SFCs were added along with some underhood braces to stop the front end structure from "matchboxing"
Car: 1971 Camaro
Engine: 427
Of course since theses cars are at least 20 years old now, the sagging has already begun.
Again, There is not a unibody car out there that would not benefit from connectors.
There is no reason not to have them.
Car: 84 SC Camaro (92 Tribute)
Engine: V6
Transmission: M5
Seems as though most of the talk is about hardtop cars. Are the T-top cars and Verts any more or less rigid than a hardtop? I'm guessing they all benifit from the addition of them. I never really thought about adding them to mine. I've always just considered it a weekend, nice weather driver. After reading through this, I can't wait to add the set that came on my roller I just bought to mine.
Car: 1971 Camaro
Engine: 427
Do you think a t top car would be more ridged? Converts have more bracing but thats to compensate.
Again, ALL unibody cars will benefit from them, hard tops, t tops, converts...
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
T Tops need them more than hard tops they flex so much more
Unless you like to drive around on cold days making recordings for hounted houses
Car: 1971 Camaro
Engine: 427
Engine: V6
Transmission: M5
Car: 1971 Camaro
Engine: 427
Car: 88, 89 & 91 GTA
Engine: 355 Super Ram/350
Transmission: TH-375/700R4
Axle/Gears: Currie Ford 9"/3.70
My opinion, pay to get the weld in ones if you don't know how to weld....you won't be disappointed.
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
my car is a t top car and I had a crack on the drivers side. just behind the door on that side pillar. right where that meets the top of the door. Drilled a hole to stop the crack, then welded it back shut. then did the body work. I think SFC are very nice. You can definitely feel the difference. lol...plus my car is lowered 2 inches. Makes a huge difference going around corners!
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
luvofjah
Sep 26, 2015 08:28 PM
