IROC cluster into Sport Coupe?
Old Jun 29, 2001 | 05:16 PM
TransAm383's Avatar
I plan on buying an 84 SC that is a real strippo job. Where the tach normally is, there is the gas gauge etc. Anyway, I as wondering if it would be possible to swap in the entire cluster(145 speedo, tach, etc.) from an IROC or Z-28 into this car without any cutting or fancy mods? Thanks for any help.
Old Jun 29, 2001 | 05:42 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Yes, it will plug right in (at least it worked in my 84sc). Just be shure to change out the idiot light sensors for true gauge sensors,, the biggest PITA is the oil press sensor (I've yet to change mine so the gauge is pegged when the car is on).
Don't be shocked when you get a temp sensor & the car says it's running hotter then hell,,, I've tried 3 diff ones (delco, borg warner & whatever crap ones they sell at autozone)in my bird and they all read high,,
My gauge creeps to 22o° with a quickness even though the thermo (which is a robert shaw 18o°) has yet to open. I'm not shure of why this is,, but it is,,, if you can,, get the temp sensor from the car you get the gauges.
Hope that's of some use
The mind is like a parachute, it only works when its open
[This message has been edited by deadbird (edited June 29, 2001).]
Old Jun 29, 2001 | 10:41 PM
TransAm383's Avatar
Thanks. I think I'll give it a go.
Jeremys87
Jul 14, 2022 09:08 PM
downsouthboy
Aug 29, 2015 11:29 AM
ChevyZ71
Aug 13, 2015 07:30 AM
mustangman65_79
Aug 11, 2015 03:17 PM
