plastic bumper repair?
Old Mar 11, 2013 | 08:00 PM
hardroc's Avatar
ok my 88 irocz when i got it has had some mild damage to it. but on the frnt bumper cover is broke. the lips where the bumper cover sandwiches to the fender are broke off andallowing the bumper to sag. i tried to get it to stay put by re sandwiching the piece that isn't broke no luck.. my question s would it be able to reglue these pieces back on and them hold it is a perfect cover other then that and i would hate to have to find another to replace it. if this plastic welding or pu glue repair stuff will work i would rather do that.
any insight would be helpful
Old Mar 11, 2013 | 11:05 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: plastic bumper repair?
You can re glue them. I'm having the same issue with my bird nose. I may save myself the trouble and have a shop do it though
Old Mar 12, 2013 | 02:17 PM
hardroc's Avatar
if it can be done ,considerig the small area of material to work with i will do it just dont know how well it will hold
Old Mar 12, 2013 | 02:37 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Plastic welder and a 2 part bumper filler.
Old Mar 13, 2013 | 05:20 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
The problem with these tabs is:
1) They're intended to provied some amount of flex (for alignment,
and vibration.)
2) Once broken, they're very fragile to repair back to original strength
for above.
I have the same issue on my 'bird, and my intended solution will be to
re-inforce the tab with a thin metal (aluminum) backing with a large
area glued to the body of the bumper, that will provide adequate strength.
Good luck, and keep us posted.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
ironbmt
Sep 27, 2015 06:00 AM
Night rider327
Sep 25, 2015 04:19 AM
evilstuie
Sep 24, 2015 12:04 AM
