Hood luvers
Hood luvers
Can a 88 iroc-z hood be modifyed to make the luvers work. I like the look and don't want to change it to much.But it would be mint if they worked. The 82_83 looks more of an open ram air type and I have to drive it rain or shine
88 Camaro IROC-Z
350TPI
K&N filter , High flow exgaust (no cat's), automatic tran's shift kit
88 Camaro IROC-Z
350TPI
It would be impractible to even try. If you ever looked at the actual IROC race cars, you'd see that the louvers were actually part of the hood. If you really want something like that, you'd be best off making your own fiberglass hood, or finding someone to make you a one-off.
'86 Camaro Sport Coupe
you can do it, I was thinking about it for a while, If you can rig up a set of small motors with two pullys to change the ratio for power you could make then power open close. Leave the lovers alone and cut out the hood underneath them then rig up a set of rails with seals, make sure you lube it with vasoline or something and then attach the motors to a window switch of some sort. It is possable, I need to look into a little futher but you know....
blue 502
Spanks for the crome wheel tip, I will say somthing to the shop when I get mine done.
88 Camaro IROC-Z
350TPI
88 Camaro IROC-Z
350TPI
Six Speed
That's a good idea to make them open and close. I will take that insulation out to see how the louvers come off. On the 2nd gen's did they have a cowle hood that opened when the four barrarle's opened up.I'm going to see if I can find one of these in the junk yard.Maybe one of those motors will work with a few mods.
88 Camaro IROC-Z
350TPI
88 Camaro IROC-Z
350TPI
The only reason you should make them funtional is to release hot air from the engine compartment. The hood is a low pressure area (vaccume) and will only draw air out. The front bumper and cowl areas are high pressure.
<font face="Verdana, Arial" size="2">Originally posted by nicmike85:
The only reason you should make them funtional is to release hot air from the engine compartment</font>
That is what I'm trying to do.Run your car and feal the top of the intake(hot). If I can let more hot air out more cool air can come in.And with doing the free mod that involves taking the coolant line out of TB it will be much cooler air.
88 Camaro IROC-Z
350TPI
<font face="Verdana, Arial" size="2">Originally posted by Going Slow Sucks:
I don't know how to use the Quote properly
</font>
</font>
88 Camaro IROC-Z
350TPI
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
