My window wont roll up!!!!
Old Jul 3, 2001 | 09:30 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Manual windows. Ok, it rolls up about 75% of the way and then it just jams. What should i look to replace? Also, do i NEED the special tool to get the window handle off or can i use a screwdriver???
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
Old Jul 3, 2001 | 11:18 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Yes you can get it off with a screwdriver, just make sure its a long, thin one. If you're despirate you can use a credit card (or similar plastci piece). Most of the binding up come from the window gear, track & moving points not having been greased/lubed in awhile. I've always trusted white lithium grease for the hard to reach areas, it sprays like WD40 but is true grease.
The mind is like a parachute, it only works when its open
[This message has been edited by deadbird (edited July 03, 2001).]
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
FormulaEngland
Sep 30, 2015 01:50 PM
