Bouncing Speedo-Needle
Old Jul 4, 2001 | 07:52 AM
Cam350TBI's Avatar
Please help:
I have already removed the cluster several times and are tired of it now. I have removed the cable and lubed the cable(w/ spray white lithium grease). When I reinstalled the cluster I was careful to make sure everything was lined up correctly. The speedometer was sent out recently to have the tripometer fixed and the speedo recailbrated. Any ideas on what to do next? Help!!! Thanks in advance.
Old Jul 4, 2001 | 09:01 AM
un4givin89's Avatar
I have a bouncing Fuel gauge. I can't tell what the hell I ever have in there, but I never fill it up more than 8 gallons every time it says empty. So either the damn thing works like crap or I have an 8 gallon tank.
Old Jul 5, 2001 | 12:33 PM
irocdaddy's Avatar
Car: 89 iroc,2012 eco 150,roadglide
Engine: zz4
Transmission: t56
Save yourself alot of grief; put in a new speedo cable and it will stop bouncing.
89 iroc,zz4/700r4/3:70 gears/koni yellows/herb adams bars/and alot of other crap to make it work!
Old Jul 5, 2001 | 09:16 PM
Cam350TBI's Avatar
Replace the speedo cable huh?
Now the question of do I replace the entire cable from trans. to speedo? Or, the "half-way" part (the one you can pull out when you remove the cluster? I assume the "half way" one? Sorry for the ignorance.
Nighthawkf-117
Sep 24, 2015 02:47 PM
buckeyecelt
Sep 24, 2015 05:50 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
