cranking problems
Old Jul 9, 2001 | 02:59 PM
Amber's Avatar
cranking problems
Hey guys a friend of mine has a 1991 RS Camaro. This is the prob. Her car will sometimes crank but not always.
she has checked the following:
altenator, wires that run from starter to park and neutral, battery cables, wires from starter to fuseable links.
All these things were fine.
She just replaced the starter and cylanoid. This happens most often after the car has been runing. Does anyone have ideas what might be the problem?
A.
Old Jul 9, 2001 | 09:10 PM
Jza's Avatar
Jza
When it does it, try tapping on the solonoid with the butt of a screwdriver. Our starter solonoids are so close to the exhaust system that they commonly experience heat soak and stop working until they cool.
The solution to that problem (if that's actually what it is) is either a heat shield/heat wrap for the starter and solonoid, or a remote solonoid similar to Fords (but don't use the Ford part because they're notorious for crapping out).
mddaniel
Sep 8, 2015 05:16 PM
downsouthboy
Aug 29, 2015 11:29 AM
355tpipickup
Aug 27, 2015 08:13 AM
overdriv
Aug 20, 2015 03:52 PM
