spray painting my door jams. what primer??
Car: 89 Camaro RS (lawn ornament)
Engine: 327 sbc
Transmission: TH350
Axle/Gears: Stock for now
My 89 is white (and looks terrible) I'm going to paint it GTO cosmo purple. I had a local paint shop load me up a spray can to do the jams. I pulled the door off and removed everything in the way. I scuffed the jams real good with scotchbright. Now here is the question. I'm half tempted to just lay the color down, but I feel I should prime it or seal it prior to color so it has a nice uniform layer to adhear to. I don't want to have to sand the entire jam again before paint so can I get some primer/sealer (spray can) and then shoot the color over that? I'm just trying to save time here. This isn't gonna be a show car but I want to do a good job.
Engine: 327 sbc
Transmission: TH350
Re: spray painting my door jams. what primer??
come on guys. Sealer over old paint, or prime and sand???
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
On mine i sanded and primered it to black, then sprayed the original color, with a couple coats of clear, hell man, you could play around with different ways and see what you think looks best.
P.s. forums been kind of slow recently lol.
Engine: 327 sbc
Transmission: TH350
i was mainly wondering if primer/sealer would stick to the old preped paint and be a good surface to lay my color? If I sprayed it with primer/sealer I could just let it flash dry and put my color down right? Or would it look like ****?
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
If your going to go cheap just rattle can the jambs...
Here is what some skill and $16 dollars can get you...
before:
Sanded everything down with 120, 220, rattle primmer:
after, rattle paint with no clear:
before:
Engine: 327 sbc
Transmission: TH350
what did you sand the primer with before paint? How much time did you spend on sanding them
probably spent an hour or two hand sanding the entire jambs on this particular car, after sanding, i just laid down primmer let the primmer dry for a few hours (colder weather) then i painted, laid 3 light coats with a 10 minute flash time in-between coats, then laid slightly heavy coats till i got the right build up.
Engine: 327 sbc
Transmission: TH350
so you didn't sand the prime? So I could definitly do it like you, but use sealer/primer or regular rattle can prime and silver scotch brite it or something
Yeah i didn't sand the primmer just laid paint on top of it. You can use what ever, sealer is a safety if your worrid about **** showing up, but if you have a oem surface just a good primmer will work stick with the same brands... i would encourage you to sand rather then use a pad, iv seen and delt with a lot of **** poor jamb jobs because people are to lazy to spend the time to get all the edges, curves, corners etc. Its all ways the prep work that leads to a nice paint job.
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Engine: 327 sbc
Transmission: TH350
sounds good. I have some duplicolor high build I can shoot them with. I'll see how smooth it is when it dries then sand accordingly.
Engine: LB9/3.1
On one of my other thirdgens jambs, i spent a few days sanding and fixing the imperfections, i laid down etching primmer, sealer, high build and knocked down about 95% of the high build... Much more elaborate.
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Probably best off sanding/scuffing it down thoroughly. If you don't get it down to metal, I would apply a sealer that closely resembles your base color and roll with the color and then clear. Sealer is smart when you are changing colors, will use less base in the long run.
Car: 1989 5.7 IROC Dark Red/Blk 92Z28
Engine: 5.7
Transmission: 700R
Don't forget to share your results.. planning on doing the same thing.. stone
ambainb
Apr 25, 2016 09:21 PM
