What to replace during repaint?
Old Apr 1, 2013 | 07:54 PM
71nova's Avatar
Car: 1990 Iroc Z
Axle/Gears: 9 bolt
I need to compile a list of things to replace while having my car repainted and an idea of where to get it so I can do it while the car is apart. I need a list of any gaskets I should replace and anything else that anyone else thinks of. Any info is greatly appreciated. I dropped my car off at the shop today. I really want to save this car and hopefully not have to do anything twice.
Old Apr 1, 2013 | 08:00 PM
71nova's Avatar
Car: 1990 Iroc Z
Axle/Gears: 9 bolt
Re: What to replace during repaint?
pic
Old Apr 1, 2013 | 08:28 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Maybe mirror gaskets,if needed,check weatherstripping,your antenna grommet,just to mention a few.
http://www.moderndaymuscle.com/inc/sdetail/163/905
http://www.moderndaymuscle.com/inc/sdetail/163/904
http://www.moderndaymuscle.com/inc/sdetail/163/871
Old Apr 1, 2013 | 08:52 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
do not , do not forget the outer window sweeps . remove old ones before paint . old cracked window sweeps make a primo paint job look like $hirt . good luck .
Old Apr 1, 2013 | 08:55 PM
71nova's Avatar
Car: 1990 Iroc Z
Axle/Gears: 9 bolt
Thanks for the quick reply. mirror gaskets and antenna gromet were things I hadn't thought of. I'm planning on replacing all of the weatherstripping I have the outer window sweeps already. Keep the ideas coming and maybe the exact names of the weatherstripping. I'll start making a list and check it with what's on the car and save what might be worth saving.
Old Apr 1, 2013 | 09:04 PM
71nova's Avatar
Car: 1990 Iroc Z
Axle/Gears: 9 bolt
I bought the car back in 09 for 1200 and I think it deserves a repaint hopefully I'm not making a major mistake. I don't really want to cut corners. I'm going with the original color but not painting the engine bay. The clock sits at 86000 and it runs good may have engine bay painted later if it needs a transplant or rebuild.
Old Apr 1, 2013 | 09:10 PM
LHernandezJr's Avatar
Old Apr 1, 2013 | 09:15 PM
mantaguy's Avatar
Engine: 5.0 EFI
Originally Posted by motobooks
I'd also replace the windshield trim.
Very good Idea
Old Apr 1, 2013 | 09:17 PM
mantaguy's Avatar
Engine: 5.0 EFI
And of course http://www.phoenixgraphix.com/gm/8890iz.php
Old Apr 1, 2013 | 09:21 PM
mantaguy's Avatar
Engine: 5.0 EFI
Thankfully you don't need T Top weatherstripping,you could go with GM,a little pricey but their the best and you can't go wrong, their are alternative brands,Metro,Softseal and a couple others I can't think of off hand.
Old Apr 1, 2013 | 09:28 PM
mantaguy's Avatar
Engine: 5.0 EFI
Old Apr 1, 2013 | 09:35 PM
mantaguy's Avatar
Engine: 5.0 EFI
http://www.classicindustries.com/cam...ts/g6647.html#
Very Pricey!!!!That's just a door
Old Apr 1, 2013 | 10:00 PM
71nova's Avatar
Car: 1990 Iroc Z
Axle/Gears: 9 bolt
Windshield will be taken out for paint and possibly replaced. The body shop said that I may want locate a new windshield trim or the windshield guy would use a universal one. I need more info on this matter definitely.
Old Apr 1, 2013 | 10:13 PM
71nova's Avatar
Car: 1990 Iroc Z
Axle/Gears: 9 bolt
The body shop owner looks at me like I'm crazy when I tell him I'm not sure on the decals. I guess he is right. Are these just like the originals. I just don't want them to look bad or put on wrong. I would like them on the car because it is how the car came. My car also has pinstripes but the body man thinks they were added at the dealer. What do you guys know? There is also the body moulding debate to go over.
Old Apr 1, 2013 | 10:20 PM
71nova's Avatar
Car: 1990 Iroc Z
Axle/Gears: 9 bolt
oww!! How are the other options? What makes these better?
Old Apr 1, 2013 | 10:29 PM
mantaguy's Avatar
Engine: 5.0 EFI
Their GM,I found this thread for your windshield gasket.
https://www.thirdgen.org/forums/body...ght=windshield
Old Apr 1, 2013 | 11:18 PM
71nova's Avatar
Car: 1990 Iroc Z
Axle/Gears: 9 bolt
It looks like Camaro Central has the windshield gasket. I bought my outer sweeps from them at Carlisle last year. If it takes more than 24 days to paint my car maybe I could hit them up at Spring Carlisle this year and work a deal on some stuff in person if they do the show. That's a lot of ifs though. Good thread on the gasket. I may try and reuse the windshield for a while to save a couple bucks. I definitely will be needing a new gasket mine is starting to fall out and actually looks a little short on both sides toward the bottom of the windshield.
Old Apr 2, 2013 | 12:19 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
If your not totally trying to restore it back to its original state than shave the antenna. Makes for a much cleaner look.
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
eddie jr
Aug 25, 2015 06:52 PM
Wife'sCar
Aug 22, 2015 01:46 PM
NBrehm
Aug 5, 2015 07:57 PM
