I just pushed the button in and it didn't pop back out. I know this is common because I have seen two other camaros with the same problem. The small spring clip in there is broken in two. Can i just go to a boneyard and get one from another camaro and put it in?
Jeremy
91 rs, convertible, K&N, Edelbrock open element cleaner, 3.73, B&M mega-shifter, goodmark cowl-induction hood,tinted windows,MacEwen Overlays
Coming soon...non red interior with 4th gen charcoal/grey seats
Jeremy
anyone?
Jeremy
Jeremy
Mine has been broken for 5 years, and everyone in the boneyard that I have found is broken too, good luck
92 Camaro RS 5.0 5-Speed (Quasar Blue)
T-Tops
14" Open Air Cleaner
3.08 Posi-trac
Edelbrock TBI Intake
Crane cam
Ported & polished stock heads 3 angle valve job
HyperTech Chip
SLP Headers (Ceramic Coated)
UltraFlo cat-back exhaust
74 Dodge Dart Sport 360 (11.2 1/4 mile)
2000 Dodge 1500 Ram Sport
T-Tops
3.08 Posi-trac
Crane cam
HyperTech Chip
lonsal
close
I've repaired mine many years ago. The part that broke was the bent spring steel clip. I replaced it with a coil spring. It required drilling a cavity to allow for the spring. But it has never broken again. I guess I need to revisit making a repair kit for this. Thanks for the reminder.
90 RS Convertible
Owner: Top-Down Solutions
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
90 RS Convertible
Petes 84Z28
close
A quick tip...remove those broken pieces of spring right away; I didn't, and one of them worked it's way down and jammed the latch in the closed position. I had to use a screwdriver to pry it open and it busted the button.
Pete
Pete's Place
HiOutput Tech Page
83 SC
originally a V6...now
210+k mile LG4/5-speed
14.891@95.54
Pete
Pete's Place
HiOutput Tech Page
83 SC
14.891@95.54
i got the spring clip out, it is broken in two, but I want to get it fixed, i tried the spring thing, but had a problem with finding a good sized one for there. I will have to visit the boneyard for a new clip maybe. Or rig a spring in there.
Jeremy
Jeremy
My buddys car had the same problem and he to could not find one at the junk yard!!! So what he did was take the whole lid off and put velcro strips on to!! So instead of opening the whole lid comes off and just snaps back on!! It sounds kinda of funny but it works!!
Hey on your back release latch, what pops the locking part of the hatch, I added the switch and relay to my car and I get the back hatch to go up but it won't pop the lock so it just stays on the switch and goes back down.
I put a piece of foam rubber in there, because I couldn't find a spring that would fit.
5 years now, still works great, and no rattle!
1988 IROC Convertible
305 TBI
5 spd Manual
305 TBI
5 spd Manual
Drew
close
- Join DateJul 1999
- LocationSalina, KS
- iTrader Positive Feedback100
- iTrader Feedback Score(58)
- Liked:1,068 Times in 759 Posts
I don't suppose anyones tried a dealership for the spring? Chances are if they can get it, its less than a buck.
i tried the dealer, but they couldn't figure out what I was talking about so I am going to stop up there with the console lid to see if they can get it that way.
Jeremy
Jeremy
Petes... I had the same problem. Mine got stuck in the lock pos. So I used the screwdriver technique and got it open. After that, I ended up braking the button. It looks normal still, but the peice to lock it in is busted. Mine just doesn't lock at all anymore. I'm ok with it, so I havent fixed it yet. Junkyards usually dont have what your looking for, but it is possible.
GL,
Jay
GL,
Jay
