Tire Size on 16" irocs
Old Jul 17, 2001 | 06:52 PM
Gen X Mar0's Avatar
Car: 1991 Z28
Engine: 5.7 Stealth Ram
Transmission: Pro-Built 700R4
Whats the max tire size i can mount on my 92 RS with 85-87 iroc rims at stock height? thanks
Old Jul 18, 2001 | 08:37 AM
ATOMonkey's Avatar
I've heard of people going as wide as 265 or 275, but they had problems rubbing the inner fenders in the front. I'm not sure that wider is better for tires. If you go too wide the wheel can't support it and the tire will flex too much causing the contact patch to "squirm" and then you lose traction. It's really only for looks, not much performance gain.
'89 Red Formula 350- 350 .060 over forged pistons 232* @ .020 cam Performer RPM Holley 750 DP Vortec 1.94 1.50 Accel Coil and dist. Hedman shorty headers Dual Exhaust w/ cutouts 1LE WS6 suspension, wheels, and brakes, 9 Bolt 3.27 Posi Edelbrock LCA's & Track bar subframe connectors 700R4 Harwood snorkel scoop Eclipse Head Unit Delco Bose Speakers 2 12" Pioneer subs w/ 400 watt/chanel amp
Old Jul 18, 2001 | 08:48 AM
custman87T/A's Avatar
My 245/50/16 slightly rub the plastic inner fenders in the front while making sharp turns on my 87 T/A. My car is also lowered if that would make a difference.
Old Jul 18, 2001 | 10:36 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
On a thirdgen that was not originally equipped with p245 50 R16 tires, you may find some rubbing at full lock in the front. On the IROCs and Z28s with 16" wheels, the steering box did not allow the wheels to turn as far as on the 15" cars. I don't know about the RS camaros with 16" wheels so I'm not even going to guess.
On my IROC I've got Dunlap p255 50 ZR16 tires on the front as well as Jamex lowering springs and I do not rub at all.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jul 18, 2001 | 01:33 PM
Gen X Mar0's Avatar
Car: 1991 Z28
Well my car came factory with the 16" rims on 235 55 r16's...right now i have 245 50 r16 and i got room..i've been told i can go 275 in the back and 255 in front but 245 better for front....guy at sears auto center said i could fit 305's but working at Sears i know the kinda people the hire
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
mustangman65_79
Aug 11, 2015 03:17 PM
knight72
Aug 10, 2015 09:32 PM
