82-84 front end conversion to 85-92?
Old May 11, 2013 | 02:51 PM
Driver86's Avatar
Hey guys first time writer long time researcher, ive looked over the forums and i still cant find a detailed explanation of changing a 82-84 front end cover with a 85-92 front end cover on a camaro. I understand its possible but what is involved in doing this? also the side skirts from a 82-84 switching to a 90-92 are these bolt on or is it more of a process?
Old May 11, 2013 | 04:54 PM
Coolwheels84's Avatar
Car: 84 SC Camaro (92 Tribute)
Engine: V6
Transmission: M5
Re: 82-84 front end conversion to 85-92?
If your car already has gfx, it wont be too bad. It is a lot of work though. First off, make sure you get a matching set. The 85-90 gfx are different than 91-92, so pick which style you like and go with that. You are gonne need a 85+ front bumper cover, front gfx, grill, fog lights and brackets (if wanted) rocker and door gfx, rear qtr gfx and matching rear bumper. The toughest part is that you are going to have to remove ALL the interior plastics including the door panels and rear seats to do this swap. The front bumper isn't bad. Remove your bumper and gfx and replace it with the new bumper and gfx. To remove your side gfx you must remove the door panels, rear seats, and rear interior plastics. There is a hidden bolt inside the body panels by the rear seat bottoms. Once all that is removed you will be able to see where everything else is bolted in. Remove your gfx and install new ones. For the rear to match the front, you must change out the rear bumper and rear qtr gfx. To do that you will need to remove the rear interior plastics, tail lights. With that out of the way you can see where all the bolts are inside the rear qtrs that hold the bumper to the rear qtr. Remove all the fasteners on the top of the bumper cover and underneath. The bumper will come off now. Remove the rear qtr gfx and replace with the new style and new bumper. Reinstall all your interior and you are done. I did it with my car which had NO gfx from the factory. It is A LOT of work, but will look great with some hard work. Hope that helps.
Old May 11, 2013 | 05:00 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I'm waiting for someone to do this near where I live...I'll gladly take all those nasty 82-84 GFX off their hands!
Old May 12, 2013 | 09:00 AM
Driver86's Avatar
thanks alot coolwheels! does anyone know if all the bolts match up? I have a 83 Z28
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
bellez77
Sep 5, 2015 08:39 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
