Limp driver's side mirror - fix?
Old Aug 12, 2001 | 03:51 PM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
The driver's side mirror (not power) on my 91 Formula was nailed by some jerk at work. The mirror itself survived with only a couple niks at the bottom (I'll probably replace it anyway tho), but it hangs kinda limp now. The controller ****/joystick inside still moves it, but it seems like the tension in the top cable (of the three cables running from mirror>>****) is not enough to hold it anymore. I'm guessing the cable was stretched by the impact?
I took it all apart, but didn't see any simple way to fix this, short of replacing the whole system - any suggestions (thanks in advance)?
JoelG
91 Formula, red
Edelbrock open element air
(no other mods yet - too much t/$ already into getting it back to normal from misc. damage & abuse!)
Old Aug 12, 2001 | 08:10 PM
Blue_Meanie86SC's Avatar
Limp huh? Try Viagra.
sorry, had to say it.
Anyway, I think the only way to fix it is to replace the whole mirror assembly.
Old Aug 13, 2001 | 09:50 AM
Car: 91 Formula
Engine: 305 TBI
Viagra, hahaha
Actually, I took it apart again last night. I wrapped the cable that holds the mirror up tightly with wire just below the terminal metal barrel at the ****/joystick end. This extended it (it now sits about 1/4" further out in the ****'s slot. This gave me back the tension needed to correct the mirror's erectile disorder (w/o the 'scrip!).
So far (one commute to work), so good - I'll post if this goes bad or anything. If this happens to you and the above sounds too vauge, email me and I'll help you if I can (it's not that complicated, tho - I should have at least tried it before posting here and using up y'all's valuable time).
Thanks,
JoelG
Old Aug 14, 2001 | 07:38 AM
kurgen's Avatar
if you cant duct it....f(_)ck it! lol
Bert87
Aug 23, 2015 03:50 PM
86IROC112
Aug 20, 2015 12:18 PM
Cameeeero
Aug 20, 2015 03:06 AM
89FormulaMan
Aug 10, 2015 10:01 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
