rear window louvers (need help)
Old Jun 13, 2013 | 09:48 AM
tarouty's Avatar
How do I install these rear window louvers ?
I think it will fly
Old Jun 16, 2013 | 09:28 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: rear window louvers (need help)
The mounting clip slides over the edge of the window. That clip shown is the one that is at the top left or top right side of the louvers. The clip slides over the black metal rear hatch trim and has little indents that grab the edge of the black trim (on the glass side) and keep the clip from coming off the trim. The screw on the louvers twist 1/4 turn and lock the louvers to the mounting clip. The factory set of louvers had two hinged mounts at the top of the window, two on each side of the window and one that used double sided tape on the bottom of the window itself.
Old Jun 16, 2013 | 11:10 PM
tarouty's Avatar
I mean how can the screw that holds in clip
Old Jun 17, 2013 | 01:53 PM
scottmoyer's Avatar
That looks like the wrong screw. They need to be Dzus fasteners. They 1/4 turn and pull down on the louvers as they turn on the spring assy.
Old Jun 17, 2013 | 03:06 PM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
they twist into hook latch/holes on the rear glass & then just hook into place w/allen wrench, you need the other part they go into, should be 4-6 of them......
Old Jun 17, 2013 | 03:07 PM
Lakerman62's Avatar
oops it looks like you have everything, best of luck, should be easy once you do the first one......
Old Jun 17, 2013 | 03:23 PM
tarouty's Avatar
Finally, I knew the right screw ,
thank you scottmoyer
but where can I find this screw ?
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Dialed_In
Aug 20, 2015 01:45 PM
