foggy front blinkers
Old Aug 13, 2001 | 10:18 PM
Joe91Z28's Avatar
Is there a way to clean-up my nasty looking front blinkers? I took the assembly out and tried to seperate the plastic lens to clean behind it but it's glued. Any tips?
Old Aug 13, 2001 | 10:26 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Buy new ones from www.nextgenparts.com ,that
what I did.They are for my 87 RS nose and they are brand spakin new.
[This message has been edited by 85SportCoupeto89RS (edited August 13, 2001).]
Old Aug 13, 2001 | 11:21 PM
zee28's Avatar
Car: 86 iroc
I agree .it makes a huge differance in the looks.and you will never get them as clean as new.after you get them ,cut the liitle drain so water doesnt get in them anymore.(see recall page).and never wipe them dry,they scratch easy.
~mike~86 IROC-Z
Old Aug 14, 2001 | 12:27 AM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
I have a set of new ones up for sale on ebay.check it out....oh and these are still available from the dealer....
Old Aug 14, 2001 | 06:01 AM
Joe91Z28's Avatar
Thanks for the help guys, I'll look into some new ones.
Old Aug 15, 2001 | 03:51 PM
aerofox_1's Avatar
what I did for mine was sand all the tiny letters and numbers of the front and then cover the lens with 5% window tint. I did it two years ago and it still looks great.
Old Aug 16, 2001 | 04:52 PM
Chuck Everly's Avatar
You can get new ones for $27 each.
I got mine through Dal at http://www.worldparts.com/vandevereoldsmobile/ He sells all parts 10% over cost.
Old Aug 16, 2001 | 04:56 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Anyone know the part number for these things?
Old Aug 16, 2001 | 06:24 PM
For years 89-91 (maybe others not sure);
5975682 Right
5975681 Left
Mine were $27.05 each.
Old Aug 21, 2001 | 04:08 PM
ian's Avatar
ian
Car: 83 berlinetta
Transmission: th 700
i hacksawed the front lens off cleaned them out then a couple of dabs of super glue tohold them in place so that you can reseal around the edge with clear silicone did mine 2 years ago and still look like new
Old Aug 21, 2001 | 04:43 PM
Jza's Avatar
Jza
Those part numbers are correct, and will also fit Z-28s with ground effects back to 85 (not Sport Coupes!). And new ones definitely look better then anything you could possibly do to clean up old ones. Believe me, I tried before I forked out that money, and yet I don't regret spending it.
Old Aug 21, 2001 | 10:00 PM
Abubaca's Avatar
I used blue coral plastic cleaner...it worked wonders!!! TAilights too!
Old Aug 25, 2001 | 09:37 PM
Polivick'sRS's Avatar
Once you get the front lamps how do you change them do they pull out from the front or do you have to do them under the car? Thanks
Old Aug 25, 2001 | 11:59 PM
PopaPork's Avatar
Call me stupid, but this worked for my cars parking light lenses, so it might work for yours. I took black majic to them and they cleaned right up, no more fog, no more anything.....looks bran new!
89 RS Camaro
Hedman Headers, Highflow Cat, Flowmaster 80 Series
180 Degree Thermo
Open Air Element with K&N Air Filter
Custum Burned Chip
So Many Mods......so little time
www.rit.edu/~cjp8408
AIM: PopaPork
Old Aug 26, 2001 | 05:35 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
PopaPork, I thought I was the only one who used the Black Magic stuff, they make my taillites look GREAT!
Stock 2.8 MPFI auto w/ Flowmaster 80 Series, More to come......
New Pioneer Head Unit
Targa E-910 7-Band Equalizer w/ crossover
2x 10" Pioneer subs powered by 300 Watt Jensen amp
2- 6x9" Pioneer (rear)
More to come..... (hey, i dont got a job yet)
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
Mutillator
Exterior Parts for Sale
Oct 1, 2015 06:05 PM
Jk_Under
Sep 2, 2015 10:59 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
