Vin Number
Old Jul 2, 2013 | 05:47 PM
Adrian harrison's Avatar
Car: 1983 Z28
Engine: 400 small block :)
Transmission: 350
Vin Number
Is there anyway to find out the Ninth Digit in the vin number the Check digit?
Adrian
Old Jul 5, 2013 | 05:26 PM
Car: 1983 Z28
Transmission: 350
Re: Vin Number
I take it that's a no then?
Old Jul 5, 2013 | 05:48 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: Vin Number
It is not visible on the dash plate?
Old Jul 6, 2013 | 06:51 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: Vin Number
Do a google search and you will find out how to calculate the check digit.
Old Jul 6, 2013 | 02:45 PM
BigKeg's Avatar
Car: 87 Black Irocz28
Transmission: 700r4 shift kit
Axle/Gears: 3:73 richmend axles and eaton gears
Re: Vin Number
Vin is a acronym...meaning ( vehicle identification number ) by saying " vin number "
You are saying vehicle identification number number...where I work we call them vin stamps...
And I help build over 600 jeeps a day. ..
Old Jul 6, 2013 | 03:25 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: Vin Number
we[i]don't understand your question.
Old Jul 6, 2013 | 05:33 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Vin Number
I have always said the only dumb/stupid question is the one that is not asked . (I do wonder when I see a question like this) there must be more to this question . please explain Adrian ???
Old Jul 9, 2013 | 02:14 PM
Car: 1983 Z28
Transmission: 350
Re: Vin Number
nothing much to explain, only that the Ninth Digit is the only one I cannot read on the dash as there is way to much rust to read it.. that is way I was asking on here how to work out the digit
Adrian
Old Jul 9, 2013 | 03:38 PM
scottmoyer's Avatar
Re: Vin Number
http://www.alton-moore.net/vin_calculation.html
http://www.vsource.org/VFR-RVF_files/BVINcalc.htm
To determine check digit (9th digit) you need to take the VIN and assign any letters in the VIN with a set value (number) as follows:
A = 1, B = 2, C = 3, D = 4, E = 5, F = 6, G = 7, H = 8, J = 1, K = 2, L = 3, M = 4, N = 5, O = 6, P = 7, R = 9, S = 2, T = 3, U = 4, V = 5, W = 6, X = 7, Y = 8, Z = 9
Any numbers in the VIN remain the same and thus you have a 17 digit number.
Then you must multiply each of the 17 digits by a set "weight" (multiplier). The weight applied to each digit is as follows:
1st = 8, 2nd = 7, 3rd = 6, 4th = 5, 5th = 4, 6th = 3, 7th = 2, 8th = 10, 9th = 0 , 10th = 9, 11th = 8, 12th = 7, 13th = 6, 14th = 5, 15th = 4, 16th = 3, 17th = 2
Notice that the 9th (check digit) is multipied by 0, and therefore not factored into the equation to determine itself.
After multiplying each VIN digit by the associated weight - add up the results of all 17 products. Then divide by 11 and the remainder is your check digit.
If the remained is 10, then the check digit is 'X'.
He the applied this formula to the VIN I used on my page. This VIN, I made up, to illustrate all the examples for my page. At the time, I did not know what the "check digit" was, and just picked a number arbitrarily. For the formula, he used the correct check digit, which I will use, when I update my site.
Here's the example: VIN = 1G1YY21P2E5999999 (note '2' is the check digit)
VIN....................1 G 1 Y Y 2 1 P 2 E 5 9 9 9 9 9 9
Assigned Values...1 7 1 8 8 2 1 7 2 5 5 9 9 9 9 9 9
Set Multipliers......8 7 6 5 4 3 2 10 0 9 8 7 6 5 4 3 2
Add the products: (1 X 8) + (7 X 7) + (1 X 6) ... (9 X 2) = 541
8 49 6 40 32 6 2 70 0 45 40 63 54 45 36 27 18 = 541
Divide 541 by 11 which gives you 49, and a remainder of 2 which is the same as the 9th digit of the VIN.
Old Jul 9, 2013 | 03:55 PM
Car: 1983 Z28
Transmission: 350
Re: Vin Number
ok thanks for that, just going to work so will try this later
Adrian
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
3.8TransAM
Sep 27, 2015 08:37 PM
