under dash panel
Old Sep 5, 2001 | 06:48 AM
elizabeth's Avatar
under dash panel
I have a 90rs.The panel that holds the fuse panel won't stay in place. It falls down whem I am driving; used velcro to hold up the fuse panel to the larger panel but velcro won't work to hold the larger up...help please
Old Sep 5, 2001 | 06:54 AM
Purple 92 SS's Avatar
Car: 1992 Z/28, 2000 SS, 1968 RS/SS
Engine: 355 Built a bit / LS1
Transmission: T-5 / A4
Axle/Gears: 4.10 / 2/73's
<font face="Verdana, Arial" size="2">Originally posted by elizabeth:
</font>
in mine i took it completely out. I didnt see a need for it other than getting in the way when i need to check fuses, and i couldnt tell it was there when i was sitting in the car so i yanked it out.
hope that helps.
-steve
92 RS/SS FrankenCamaro
More mods to list than time to do it in
www.groundzerocustoms.org
Old Sep 5, 2001 | 07:09 AM
elizabeth's Avatar
With the panel out the wires fall down; I'm afraid I will pull one out by accident. Thanks!
Old Sep 5, 2001 | 08:10 AM
With the panel out the wires fall down; I'm afraid I will pull one out by accident. Thanks!</font>
interesting.. when i pulled mine i dont recall the wires falling.. oh well.. if all else fails try wire tying everything up.
hope that helped.
-steve
Old Sep 5, 2001 | 11:08 PM
85 Berl's Avatar
Try using zip ties. It may look tack to some, but it is very effective.
Old Sep 6, 2001 | 02:45 AM
elizabeth's Avatar
I tried what yow said and it does work. Thank you both for your ideas I sure don't know all the tricks. It seems to me though, that when the computer was replaced the man took out some type of clips.
Old Sep 6, 2001 | 07:51 AM
</font>
thats quite possible. I myself am in the process of taking apart my entire interior, including dash. I have a wireing mess and need to clean it up. good luck with your car and welcome to the board.
-steve
Old Sep 6, 2001 | 07:58 AM
elizabeth's Avatar
Thank you all! I'm so glad I found this site. So much info that I can and have used!
Old Sep 6, 2001 | 09:51 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I had the same problem with my 90 RS. The plastic tab that is supposed to hold it in place broke. Here's how I solved it. Get a large washer (AKA fender washer) from the auto parts store. Put it in a bench vise and bend about 1/3rd of it up 90 degrees. Then mount the washer in the hush panel adjacent to the fuse panel cover with a screw & nut. Mount it so the panel will release when you move the part that has bent up (or in this case down) is over the fuse panel. When you want to reinstall it push it back in place and rotate the washer. The tab you bent gives you something to easily hang onto and provides the latching method. In re-reading your post, you are describing the larger panel that contains the fuse panel. There are three clips in the front (closest to driver) that hold the larger panel in place. The clips have either broken or fallen off. The HELP section at Pep Boys or other good auto parts stores will have replacement clips. The rear part of the panel is held on by a threaded post.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
[This message has been edited by lonsal (edited September 06, 2001).]
Old Sep 6, 2001 | 10:03 AM
elizabeth's Avatar
thank you Lon, Mine has a post in the back but nothing secures it- just sits there until it falls off- I will try the washer trick I might as well get everything I need at pep boys help aisle!!!
Still working on the diagnostic. A woman's work is never done!
Old Sep 6, 2001 | 10:25 AM
HrdRockA4305's Avatar
My car didn't even come with the under dash panel and i was worried about doing the same thing. I snagged a pair of those panels from some junk cars, but i've never actually bothered putting one on. The reason i didn't is we've been working on a freind of mines 85 TA and his has the panel, and i find it annoying. My feet actually almost got STUCK under the stupid thing when i was hitting the clutch pedal. I guess size 13 sketchers and sports car dashes don't mix huh?
88 Camaro (The mighty LO3 SC!)
305TBI/700R4/2.73/123,XXX miles
14" Open Element and Flowmaster 80 seires
Next up: headers and gears
Old Sep 6, 2001 | 12:03 PM
elizabeth's Avatar
I bet you were scared when your foot got stuck! I had a 57 chevy years ago and the gas pedal would fall off.
well with size 13's you are certainly well grounded! thanks
Old Sep 6, 2001 | 01:57 PM
<font face="Verdana, Arial" size="2">Originally posted by HrdRockA4305:
</font>
I actually removed mine for the same reason. it gets in the way! Plus it would have seriously gotten in the way of the neon glow i was tryin to mount under the dash.
-steve
Old Sep 6, 2001 | 02:00 PM
elizabeth's Avatar
Steve,
did you get it glowing? I bet it's great at night!
Old Sep 7, 2001 | 07:39 AM
Steve,
</font>
yes, i have a total of four tubes in the interior.. one under each seat, and one under the driver and passenger side dash board. the passenger side was much more trouble than the driver side due to the heater box.. but its all good Its a real wicked color called ultra blue, its tubes glow blue, and fade further out to purple / violet color the further you get from the tube it self.. its real cool..
-steve
if i could figure out how to take good pics of neon at night i'd show ya one day.
Old Sep 7, 2001 | 08:42 AM
elizabeth's Avatar
Steve, check out the forum "general auto/tech" I put in directions for a DIY Tool that a jogger made for me and dropped off this morning. I thought it was really terriffic and I wish I had it yesterday!!!
wigmobile
Feb 26, 2025 02:56 PM
MantyZ28
Nov 8, 2015 06:54 PM
CAMAROBEAV
European Region
Sep 12, 2015 10:04 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
Stryker412
Sep 7, 2015 09:11 AM
