Hood Question , and Hinges.
Old Aug 31, 2001 | 11:33 AM
Purple 92 SS's Avatar
Car: 1992 Z/28, 2000 SS, 1968 RS/SS
Engine: 355 Built a bit / LS1
Transmission: T-5 / A4
Axle/Gears: 4.10 / 2/73's
I have an ASCD SS hood, with or without the shocks, the hood is incredibally hard to open as it likes to flex, almost like the hinging is too hard for it to operate due to its light ness. I litterally have to wobble it up but down is no problem.
So heres teh question... has anyone/is there a replacement style hinge that would be more conventional that i can use rather than teh stock hinges. I was thinking of something that would use the factory bolts on the hood and fender but hinge differently. If there is or if anyone has any ideas/suggestions please let me know!! Thanks in advance for all your help yall.
-steve
92 RS/SS FrankenCamaro
More mods to list than time to do it in
www.groundzerocustoms.org
Old Aug 31, 2001 | 12:39 PM
Nightcruzer's Avatar
Car: Trans Am
Some people like to use the hinges with worn out small support shocks or like to use very old used hinges from an early 80's boneyard donor.
[This message has been edited by Nightcruzer (edited August 31, 2001).]
Old Sep 4, 2001 | 10:10 AM
<font face="Verdana, Arial" size="2">Originally posted by Nightcruzer:
</font>
well i tried that too, with the worn out hood shocks, but that didnt work.. whats different about the hinges from an early 80's camaro? I was thinkin that a simple hinge and prop rod would do me just fine, but i dont know where / how to get one to work with the hoods existing mounting holes.
any other ideas/ input???
thanks
-steve
Old Sep 5, 2001 | 06:33 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Well this is what my friend did on his 87 Monte SS. He took out the hinges and the latches, and put pins in the four corners. When he wants to work on the car, pull the pins, and remove hood from car. Not to mention lots of room to work that way!
Old Sep 5, 2001 | 06:51 AM
<font face="Verdana, Arial" size="2">Originally posted by Mikes86SC:
Well this is what my friend did on his 87 Monte SS. He took out the hinges and the latches, and put pins in the four corners. When he wants to work on the car, pull the pins, and remove hood from car. Not to mention lots of room to work that way!</font>
Mikesc, thanks for the input, I thought about doing that, but i dislike the look of hood pins up that high on the hood. Besides, i dont always have someone there to help me lift off a hood when i need to work on the engine/ check something out. Is there any other ideas that any of ya'll have? thanks again for your input.
-steve
double post edit.
So there is no one else out there with aftermarket hoods that have switched hinges or made it easier to move the hinges???
-steve
[This message has been edited by Purple 92 SS (edited September 06, 2001).]
Old Sep 6, 2001 | 07:37 AM
ttt
-steve
Old Sep 7, 2001 | 02:11 PM
m3baller's Avatar
i don't think that the hinges and prop would be a bad idea, you could take one from a car or make one yourself.
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
