Headlight bushing kit
Old Jul 14, 2013 | 08:05 PM
momplo's Avatar
Car: Trans Am GTA 1988
Engine: v8 5.7L 350 tpi
Axle/Gears: Dont know what this is yet :)
Hi guys so I've just opened my faulty headlight that would never pop up but the engine would keep spining on and on, and I noticed that where the 3 bushings should be, there were only crumbles of plastic. So I need to order 3 new bushings (the other one is fine, I checked it) But I can't order from top down solutions since shipping is too pricey here in canada. Have you guys come across a good kit on ebay? with or without the gear gasket is fine, i'll just reuse it if I have too. Thanks for all the replies.
Old Jul 14, 2013 | 10:38 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: Headlight bushing kit
http://www.ebay.com/itm/HEADLIGHT-POWER-WINDOW-MOTOR-REPAIR-KIT-BUSHING-PELLET-set-of-3-NEW-PRICE-/400527704982?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d414fc396&vxp=mtr
Old Jul 15, 2013 | 11:50 AM
momplo's Avatar
Are they as good as the top down solution ones? there isn't much info about it...
Old Jul 15, 2013 | 12:13 PM
IMissMy86TA's Avatar
Car: 1991 Trans Am Vert
Engine: 5.0 TPI
Transmission: T-5 baby
At Advance Auto, one can get HELP Brand Ford Window Regulator Bushings (3 in a pack) which replace the old bushings which crumble.
also fuel lines can do it too and last much longer:
https://www.thirdgen.org/forums/tech...shing-fit.html
Old Jul 15, 2013 | 12:43 PM
Car: 1984 T/A
Engine: LQ4
I'm honestly not sure. but to me they all seem the same. just molded plastic
Old Jul 15, 2013 | 12:53 PM
rhyspat's Avatar
Car: 87 firebird
Engine: 2.8 MFI
I repaired mine 3 pieces of air hose cut to the right length to fit in there. Saw that fix on-line somewhere.
Saw another article once where someone used pieces of hot glue stick.
Old Jul 15, 2013 | 02:53 PM
Engine: 5.0 TPI
its all about getting the right dimensions. used mics to measure the actual ones from a kit then measured the break lines at the auto store to get the right diameter then cut to the right width. i think it was .581 of an inch...
Old Jul 15, 2013 | 03:02 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
http://www.ebay.com/itm/HIGH-QUALITY-87-92-Firebird-headlight-motor-repair-rebuild-kit-gear/290943770303?_trksid=p2992.m2065&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D21%26meid%3D9096887608935773737%26pid%3D100026%26prg%3D1009%26rk%3D4%26sd%3D370851350047%26
Old Jul 15, 2013 | 04:02 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
You can also use 1/4-20 hex nuts fitting a 7/16 wrench. Rebuilt my last set of motors for under $2.00 after replacinf the 3 cover screws on each motor and gasket material
Old Jul 20, 2013 | 11:23 AM
Brock Lee's Avatar
Car: 1991 Firebird Formula
The ones I got from Top Down are nylon.
Hotrodboba400
Dec 10, 2019 07:07 PM
luvofjah
Sep 3, 2015 07:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
