Dual power side view mirrors
Old Sep 10, 2001 | 11:59 AM
Stolen_88's Avatar
Hello all,
Did any 3rd gens ever come optioned with dual power remote mirrors?
What about a lighted rear view mirror?
Thanks.
Brandon
Old Sep 10, 2001 | 12:06 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Yes, there are sveral cars out there with dual electric mirrors, I think just about all firebirds did standadr from 91-92. I have seen few without it. the GTA was standard all years If i remember right, you could get it delete though.
I think the first year for the T/A power mirrors was 85, havent seen it on any earlier. My elec mirrors are off an 85 or 86. The mechs will bolt right in. the most difficult part to do properly is running the wires from the driver to passenger sides.
the lighted rear view mirror, was standard in 91 & 92 for sure, I think they might havs started using the mirror with the map light in it in about 89 or so as an option do not really know.
I personally prefer the autodimming rearview mirrors. I get mine from early 90s Rivs, all you need to run is 3 wires, the Magenta color is for switched power, the green wire goes to your wire for backup lights, and Black is obviously ground.
Hope this helps.
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
Old Sep 10, 2001 | 12:57 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
My friends 1982 Trans Am came with dual power mirrors. And my 1983 Trans Am has it too...
And my 1990 Firebird has the lighted rear view mirror (Map Light).
Old Sep 10, 2001 | 02:29 PM
okfoz's Avatar
I stand corrected...
John
Old Sep 10, 2001 | 06:42 PM
gmanuel's Avatar
My 83Z28 has the dual power mirrors. I do believe the doors are replacements but i am not sure
Old Sep 11, 2001 | 06:16 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
My 85 IROC has power mirrors.
JamesC
Old Sep 12, 2001 | 08:19 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
My 89 GTA has them
Check out My Car Pics http://albums.photo.epson.com/j/Albu...667&a=13599419
Gran Turismo Americano "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs
Old Sep 12, 2001 | 08:36 PM
u r sofa king we tah did's Avatar
my 89 iroc has dual power side mirrors and two map lights on the rear view mirror
Old Sep 13, 2001 | 12:42 AM
EvilCartman's Avatar
Car: '82 Z28
My '82 Z28 has dual power mirrors.
'82 Z28
LG4 305 .030 over, performer intake, holley street avenger 670, xe 256 cam, tes headers, 3 inch single exhaust, spintech muffler, 14 x 3 inch drop base k&n.
Old Sep 16, 2001 | 07:03 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
I want to put some in my '86 while I'm on an upgrading frenzy...How difficult is it to install them in place of the original remote unit? I'm not yet sure if I want to install the switch in the console instead of the door...I can't make up my mind...that's where I think GM shoulda put it anyway...
Old Sep 16, 2001 | 11:36 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
My Formula has them....
dhirocz:
The switch for them is mounted on the console.... I'd imagine that you could just get the harnass out of a 'bird and mount the camaro switch in the same spot with it....
Almost forgot.... It has the lighted rear view mirror as well. 2 map lights.
http://kiztope.50megs.com
92 Pontiac Firebird Formula 5.7/A4
K&N, nothing else yet!
92 Rs 3.1/T-5
Beautiful car, several mods, but now I am turning attention to the 'bird!
AIM : Theonekiztope
ICQ: 8787542
"Maybe one day life will take a turn. When it does Lean into it!" Leon Calrinsky (98)
[This message has been edited by kiztope (edited September 16, 2001).]
Old Sep 16, 2001 | 11:51 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
My 89 RS has dual power mirrors also.
Third Gen Project
1989 305 tbi Camaro RS Red/Red
Ram Air II Hood
Centerline Champ 500 Rims
Edelbrock Open Element
MacEwen White Faced Guages
Old Sep 17, 2001 | 12:15 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I've installed them on my RS 'vert. If you get the entire assy, including the wiring it will be much easier. There are at least 3 versions of power mirrors. The early ones have a center screw behind the mirror glass forcing you to break the glass to remove it. Later version has a cross shaped piece which snaps onto the back of the plastic pisce holding the mirror glass. The mirrors mount to a motor which bolts into your existing mirror shells. If you have a HELM manual it will help in sorting out the wiring. Buy a set of aligator clip jumpers to help hook up all the wires and test everything out. To mount it correctly you have to pull off the dash pad as well as the door inner panels. Good luck, Lon.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
stalkier
Aug 13, 2015 12:59 PM
89FormulaMan
Aug 10, 2015 10:01 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
