Please post a 88-92 Glass T top large pin pic..
Old Jul 18, 2013 | 05:31 PM
TrueIroc's Avatar
Car: 1989 IROC-Z 100% Original
Engine: 5.0 TPI
Axle/Gears: 3.08
Hey I was seeing if any of you guys could post a picture of the Large style pins for the Glass T tops for the 88-92 years. Im trying to find a set for my 89. I have the plastic t tops that cracked and wondering if the plastic and glass have the same or different size pins. I keep looking for a glass set but all of them I see for sale have the small pins. Were all the glass t tops small pinned? Or did they make a large pin for the glass t tops for years 88-92?? If you have the correct year glass t top from 88-92 could you post a picture of the pin on here for me so I know what to get.
Old Jul 18, 2013 | 09:42 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Please post a 88-92 Glass T top large pin pic..
Dude, all you have to do is swap out your top retainers... Drop the A-pillars, remove the B-pillars, and 2 nuts hold each retainer to the body.
Yes, there are large pin glass tops. I had a set that I sold, came from a 91.
Old Jul 19, 2013 | 02:36 AM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
my 87 has large pin glass tops so yea they do make glass large pin
Old Jul 19, 2013 | 03:42 AM
TrueIroc's Avatar
Engine: 5.0 TPI
Axle/Gears: 3.08
So your saying the retainers which hold the t tops in can be swapped out?
Old Jul 19, 2013 | 03:45 AM
TrueIroc's Avatar
Engine: 5.0 TPI
Axle/Gears: 3.08
Could you take a picture of it and post it on here for me
Old Jul 22, 2013 | 04:12 AM
TrueIroc's Avatar
Engine: 5.0 TPI
Axle/Gears: 3.08
This is a small pin style from an 87 Glass t top. And a large pin style from 89 Lexan (plastic) t top. Could someone please post a pic of a large pin Glass T top from a 88-92. I want to see if its identical to the Lexan (plastic) ones
Attached Thumbnails Please post a 88-92 Glass T top large pin pic..-20130718_175503-1.jpg   Please post a 88-92 Glass T top large pin pic..-20130718_175515-1-1.jpg
Old Jul 22, 2013 | 09:46 AM
Buggy Disaster's Avatar
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
Here is the pin on my 88 iroc with glass ttops. It's the small pin. From my understanding 91-92's didn't come with glass ttops, only lexan. My 91 with lexan ttops has the large pin.
Old Jul 22, 2013 | 10:02 AM
Yenipenny's Avatar
Car: 92 RS Heritage
I bought a new 89 with the lexan tops. They soon cracked and I got them replaced under warranty. The replacement tops were glass. The pins were the same.
Old Jul 22, 2013 | 07:47 PM
knight72's Avatar
Car: 1992 W68 Firebird
Engine: 305 5.0L V8 TBI
They are
Attached Thumbnails Please post a 88-92 Glass T top large pin pic..-20130722_204157.jpg
Old Jul 23, 2013 | 04:24 PM
TrueIroc's Avatar
Engine: 5.0 TPI
Axle/Gears: 3.08
Originally Posted by knight72
They are
Thank you... Finally some proof that they did make Large Pin Glass T tops. They must be rare because that's the first picture Ive seen one and Ive been looking for a long time. My Lexan T top cracked, its from a 89 so its large pin and I want to replace them with glass tops but no one has any Large pin glass t tops for sale.... How hard is it to convert the retainers for the pins?
Old Jul 23, 2013 | 06:54 PM
knight72's Avatar
I want to replace them with glass tops...
that's what i did
...no one has any Large pin glass t tops for sale....
Got mine on Ebay.. was searching every day until i found them.
I saw a set yesterday, posted for 30 days but in less than 16hrs... GONE!
...How hard is it to convert the retainers for the pins?
Some people say they needed to ajust the the t-tops mounts/retainers just a little to close tighter. In my case, i didn't need to, just put the lexan t-tops away and put the "new" glass t-tops in.
I THINK if u go for the small pin t-tops, you'll may need to swap the mounts/retainers OR swap the latches but that may require you to modify the new t-tops to make the large pin fit.. . not 100% sure about that. Must confirm with an expert first.
Old Jul 27, 2013 | 12:12 AM
MintWS6FORMULA's Avatar
From: Michigan [Bodacious Member with the Bodacious TA'TAs (Trans Ams)]
Car: 91 Formula - Authentic and REAL
Engine: 5.0 Liter
What do you mean they didn't have glass tops in '91-2? Maybe for Camaros they only had lexan, but they had mirrored glass tops for the Firebirds. I don't have a pix of mine, but the large pins in the pictures above is what they basically look like.
Old Jul 27, 2013 | 08:08 PM
Engine: 2.7L V6
Axle/Gears: 4.41
I believe I already posted your "proof" as I already said that I had a mirrored glass set. Which I sold last year to pay for my 88. They came from a junkyard 91 down the road from me, and the VIN is on the receipt. Maybe there was a difference between whether the Birds got glass and the Camaros got Lexan, who knows other than someone who worked for GM at the time.
As for swapping the retainers, drop the A pillars and remove the B pillars. There is one screw for the weatherstripping on the front retainers, but other than that, it's 2 10mm nuts per retainer. And then you can leave the small pin retainers on even if you get the large pin tops again because the "large pins" are actually spring loaded plastic covers over the pins...
Old Jul 29, 2013 | 08:02 AM
jlarsson's Avatar
Car: 1989 TTA
Engine: 3.8L Turbo V6 - VIN 7
Transmission: 200R4
Early in 89 GM changed form the metal only pin style to the pin with the spring loaded plastic one to help with easier installation and locate it all in place much easier .. there's a tech bulleting issued about this.
Body side mounts are the same but needs, as mentioned, to be repositioned.
Old Aug 10, 2013 | 02:39 AM
TrueIroc's Avatar
Engine: 5.0 TPI
Axle/Gears: 3.08
Ok... So if the're spring loaded now the question is did they make different size retainers for the pins or were the retainers all the same size? Anyone got different part #'s for the retainers?? Maybe the retainers are all the same size and I just have to adjust them to fit better.
Old Nov 16, 2014 | 12:59 AM
shifty20's Avatar
I know this is a old thread and I am not trying to hijack but I need help and advice on a t top swap. I currently have lexan large pin t tops in my car. I have a set of glass t tops that are small pin style that even with adjustment will not fit correctly. Are all of the t top retainers the same size or did they make a small retainer & a large retainer. If so where can i find some. Or am I just over thinking things and there is a way to make my small pin glass t tops fit where my large pin lexan t tops go with only adjustment and no modifications and no parts changing?
Old Nov 20, 2014 | 08:58 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
The retainers are different. They take a matter of minutes to swap out. Get the correct retainers and your fine. Or you can swap the pin assembly from the old tops to the new and use the existing retainers. Your choice.
eightsixseven
Dec 16, 2024 01:50 PM
Street Lethal
Apr 30, 2019 12:14 PM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
dbrochard
Fabrication
16
Aug 19, 2015 06:21 PM
BrianI
Aug 9, 2015 11:52 AM
