tachometer problem
Old Sep 20, 2001 | 07:13 AM
fordsuks91's Avatar
Car: 89 Formula
tachometer problem
My tachometer in my 91 camaro is off by about a 1000 rpms to high. I have know idea how to fix it. I dont know if it has to be recalibrated or replaced. Anyone who can help would be greatly appreciated.
Fordsuks91
91 camaro rs
Old Sep 20, 2001 | 08:28 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Your tach is 1000 off to high at what RPM?
If when at rest it is too high then pull off the needle and adjust it, there was a mark on mine to where it should be aligned.
If it is on a different scale, IE & 500 RPM reads 750, at 1000 RPM reads 1500, 2000RPM reads 3000 then it might have gone bad. If course if you want to make custom white gages then mark where the correct reading is and adjust accordingly.
Just a thought
John
G O D BLESS AMERICA
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
Old Sep 20, 2001 | 02:07 PM
fordsuks91's Avatar
Car: 89 Formula
thanx i appreciate your help john. ITs always off by about 1000. From idle to when im driving.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
