Steering wheel qusetion....
Old Sep 21, 2001 | 06:38 AM
Vettegofast's Avatar
Hey all,
My cousin has a heavily modded 93 camaro Z28. I know that this is a 4th gen car, but i am having trouble getting answers. I figured someone would know here. well, heres my Q, does anyone know kinds of after market steering wheels this car, preferably racing wheels? he doesnt plan on keeping his airbag. Thanks.
Old Sep 21, 2001 | 09:35 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I have a Momo wheel in my '92, which required removing the airbag.(probably illegal, removing a safety device). I just used the adapter they sell for all Camaros.After removing airbag parts, went on just like any other.Just about every manufacturer makes a
wheel/adapter combo that will fit a third gen.Don't know about 4th, but likely to be the same, since it would be cheaper for GM to keep using the same thing.Idiot light on dash for airbag needed to be removed,as it stayed on all the time.Some have said this swap was a pain, but I didn't have any problems.If you're at all mechanically inclined and can borrow a steering weel puller,you shouldn't have any problems.
1992 RS,5 Speed,T-Tops,Eibach Springs(cut), KYB's, Lakewood Trailing Arms and Adjustable Panhard Bar,Posi Disc Rear,3.73 Gears,Summit Rearend Support Cover,
Del-A-Lum Bushings,300 HP Crate Motor,Crane Comp-U-Cam,Edelbrock TBI Intake, Turbo City Ported Throttle Body and Adjustable Fuel Pressure Regulator,Open Element
Air Cleaner, Ground Control Strut Tower Brace and Caster/Camber Adjusters,SLP 1-5/8" Headers,Flowmaster 3" American Thunder Exhaust,3" Cat,Centerforce Dual
Friction Clutch,Hayes Billet Flywheel,B&M Power Steering Cooler,Big Thumpin' Stereo.
Old Sep 21, 2001 | 10:18 PM
zee28's Avatar
Car: 86 iroc
be prepared to swap it back to pass inspection every time.In most states anyway.
~white~86 IROC-Z
Old Sep 22, 2001 | 08:44 AM
Car: 92 Camaro RS
We only have inspection for smog here in California.They don't seem to care if a car is a deathtrap, as long as the smog equipment's in place.
Old Sep 22, 2001 | 08:59 AM
Thanks for the help all of you. A momo huh? where can he get one of those and the adapter?
Old Sep 22, 2001 | 11:13 AM
Car: 92 Camaro RS
http://www.sportscar-parts.com/steering_wheels.html is where I got mine.Part#mm2401 $65 for Camaro.Really good selection of wheels, seats and pedals at this site.
-Rich-
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
