Interior Dye Spray
Old Nov 27, 2000 | 05:02 PM
Josh 91RS's Avatar
Interior Dye Spray
Has anyone used the Dye sprays you can get out of summit to change your interior color? Can it be used on the carpet as well as the seats? How well does it work? How well does it last? Does it look original or does it look like you colored it on with a marker??? Any pictures? Thanks, thinking of changing interior to black but dont want to spend a ton of money.
Old Nov 27, 2000 | 07:04 PM
BP89IROC's Avatar
I used a similar spray on my interior. It was not the same and at the time I did not realize that there was a primer that neaded to be applied first. Without the primer it peals pretty easily but it looks great while it lasts. The brand I used actually looked better than the plastic that was already black. There is also a spray that is designed just for the carpet it works better than the other dye. Be sure to use the primer on the plastic and you should be happy with the results.
1989 Iroc-Z TPI 350 auto 4-spd Removed MAF screens K & N filters, stock other than that.
Old Nov 27, 2000 | 08:53 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I've always had good luck with Duplicolor dyes. They also have a better spray tip/pattern than regular spray cans giving you better coverage. Autozone is the only place that carries it where I live.
To add to the primer suggestion,, it's a good idea to clean the plastic well with laquer thinner or acetone and 'rough' the plastic with a scotch brite pad (and not the one from the kitchen sink )to further help adhesion.
You can also use Bulldog (or something similar) adhesion promoter to help too.
Da Boid
- 4 out of 5 people think the 5th is an idiot
Old Nov 27, 2000 | 09:32 PM
Nightcruzer's Avatar
Car: Trans Am
I used VHT vinyl/plastic dye on all my interior panels (changed from grey to black). I have had excellent results for over two years without peeling and I didn't use a plastic primer, BUT it is absolutely critical that those parts are spotless. I mean I cleaned mine twice with Marine Clean from POR-15. When I thought it was clean, I cleaned it one more time for good measure. I used a hair drier to make sure the parts were absolutely dry. Then a tack rag to remove traces of dust, and finally you have to have good spray control. Use a 50% overlap, starting and finshing before the and after the part, and use many, many (did I say many?) light mist coats, until the part has the paint coverage you want. And yes, most vinyl/plastic dyes work on carpets, but you have to make sure you get good thread penetration or it will rub off with use.
1983 T/A LG4 w/T-tops
Rebuilt/Modified E Q-jet
Custom Dual Ram-Air
Self painted cherry red w/ restored black/grey interior
Welded Comp Eng SFC
Tokico Struts/Shocks
Hotchkis LCAs and Panhard Bar
Energy Suspension bushings all around
Old Nov 28, 2000 | 04:53 PM
Josh 91RS's Avatar
So its pretty much possible to change out the entire interior if you wanted? I would want to go from gray to black. Seats, Carpets, Door panels, Headliner? Or do you think it would look like crap?
Old Nov 28, 2000 | 07:17 PM
Car: Trans Am
Yes, it is possible, but I personally wouldn't do the seats because of the constant pressure and rubbing. I don't have any experience with seats. I changed every sigle plastic interior piece from grey to black and it looks great. Then again if you think about it nothing ever rubs the interior plastic pieces except maybe for your elbow on the center console cover.
Custom Dual Ram-Air
Welded Comp Eng SFC
Old Nov 28, 2000 | 08:04 PM
86ZRICHIE's Avatar
Yeah, i agree, leave the seats to an upolstery place, the dye probably last too long. hmmm, unless maybe you took off the fabric and dyed them using Rit fabric dye which you can find at most stores. Don't know how good that will hold up, but if you could afford to get them reupolstered give it a try it could save you some coin. I'm not too sure about just spraying the carpet, wherever you have a lot of contact with feet you could potentially have the same problem as with the seats. I'd go for a replacement carpet kit, at least the front anyway. Just my 2 cents
Old Nov 28, 2000 | 08:09 PM
86ZRICHIE's Avatar
Oh, and on the headliner go to a fabric store and look for some thick, foam-backed fabric, get some 3M interior adhesive spray and you can recover the headliner.
Old Sep 23, 2001 | 08:18 PM
camaro6spd's Avatar
what if you had black seats that just need to be redyed to get their true black again. Woul it rub off onto your cloths? My nightRider seats are turning a realy dark green color, I would like just to be able to spray them black, again they were black from the factory, i just want to "recoat" them.
1987 Black 305 TPI 5spd IROC, seems to be fully loaded, but can't find RPO codes.
AIM: SzkiRM125
F-bodies : The last with-standing defense against the Invasion.
Old Sep 25, 2001 | 04:08 PM
camaro6spd's Avatar
bttt
Old Sep 26, 2001 | 03:18 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Josh, changed my interior from Tan to Black and charcoal this summer. Changed every piece. Looks awesome. Cost about $400.00 and 5 hours of time. Well worth it. Go for it.
86 Camaro Black SS Coupe, T Tops, ASCD Daytona Twin Turbo hood, Flowmaster, Custom Black Paint, Dunlop Road Kings S/R tires, Wheel Country Directional Chrome Wheels,new charcoal & gray interior including seats and door panels, leather wrapped steering wheel, shifter and emergency brake, new carpet and headliner, complete front end suspension rebuild, new Valve seals, and more mods to come
'91 RS 5.0 TBI = Waiting to be modded, but has all of the toys inside.
http://www.angelfire.com/sports/niterider/86camaro.html
Morgan_Andre@hotmail.com
Old Sep 26, 2001 | 08:03 PM
camaro6spd's Avatar
yeah, ok now my question is can i use black spray dye to re color my fading black seats and upper doorpanels?
Old Sep 27, 2001 | 07:21 PM
camaro6spd's Avatar
bttt
Old Sep 28, 2001 | 10:08 AM
camaro6spd's Avatar
bttt...again, i know someone knows this
Old Sep 29, 2001 | 11:29 PM
Blue_Meanie86SC's Avatar
upper door panels, yes, they're plastic and that dye works great on them. The seats may wear too quickly and you'd be back to square one, but you can try it and see.
Old Apr 15, 2004 | 09:12 PM
LOW&LOUD's Avatar
AIM: SzkiRM125
Sorry to dig up old post... found it in a search. But hey buddy, could you PM me some pics of the IROC-Z ya got there? If you still exist that is... Oh, and what kinda springs and wheels ya got on there? looks nice
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
RyanJB
May 7, 2016 06:23 PM
ctoledo0834
Sep 18, 2015 04:16 PM
MORREALE5
Sep 13, 2015 09:01 PM
