Part numbers for ground effects brackets?
Old Oct 2, 2001 | 09:56 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Does anybody have the GM part numbers for the steel bracket with the studs that slides into the passenger-front ground effect piece that bolts to the front fender, along with the part number for the similar bracket that holds the rocker-panel piece to the passenger fender? I need to order this stuff, but describing this part to the parts guy would be a lost cause, and I can't be there to show it to him on the computer.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 2, 2001 | 03:25 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Don't have the part numbers but hope you have better luck than I. I got the brackets but the studs were'nt threaded. Had to thread them myself. Bunch of crap.
Old Oct 3, 2001 | 12:04 AM
FrankieRider2's Avatar
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
Jim, I don't have those numbers handy, but I'll get them for you on Wednesday morning.
Karp, I've bought two sets of those aero piece brackets and they both were threaded? Maybe you just got a set that slipped through or something?
You know... nobody sweats the details like GM.....
Frankie Rider, 2
The GTA Source Page
'88 GTA Red Hatchback - 5.7L/A4
'88 GTA Black Notchback - 5.7L/A4
'88 GTA Gunmetal Hatchback - 5.0L/A4
Old Oct 3, 2001 | 08:08 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Does anybody have the GM part numbers for the steel bracket with the studs that slides into the passenger-front ground effect piece that bolts to the front fender....
Retainer, Lwr Pnl, RH: 14079878
....along with the part number for the similar bracket that holds the rocker-panel piece to the passenger fender?[/QUOTE]
I'm not sure which piece this is. As far as I know, the part number above is the owner bracket that holds the front panel to the front end and front fenders. Can you elaborate further?
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
Former Paxton (6-psig) with 50-hp nitrous: 12.043 @ 112.86 mph.
ATI D1SC (10-psig): 12.056 @ 116.62 mph.
All stats are altitude corrected for 3,100 feet using NHRA's Altitude Correction Table.
http://willie.camaro-firebird.org/
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Old Oct 3, 2001 | 09:39 AM
Jim85IROC's Avatar
I need the brackets that slide into the circled areas that have the threaded studs on them. I need the passenger side, but I didn't have any pics of that side.
Thanks for the help.
The IROC Homepage
Old Oct 3, 2001 | 12:11 PM
Engine: 5.7L TPI
Axle/Gears: 3.27:1
Jim, the front fender aero deflector brackets (in front of the wheel) are:
Front Fascia Aero Deflector Lower Bracket:
LH - 10041504 *** List Price: $6.70
RH - 10041503 *** List Price: $6.70
The brackets that mount to the aero deflectors behind the front wheel each have the same part number and are evidently interchangable:
Fender Rear Lower Deflector Bracket:
LH - 14044273 *** List Price: $8.40
RH - 14044273 *** List Price: $8.40
Hope this helps you out, Jim.
Frankie Rider, 2
The GTA Source Page
[This message has been edited by FrankieRider2 (edited October 03, 2001).]
Old Oct 3, 2001 | 02:00 PM
Jim85IROC's Avatar
It absolutely does! Especially considering that some jackass emailed me and wanted $10 for a used one.
I'll be on the phone with the dealership in a few minutes!
The IROC Homepage
Old Oct 25, 2011 | 11:33 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: Part numbers for ground effects brackets?
Have we found an after market source for these?
1992 Trans Am
May 10, 2023 07:19 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
Mutillator
Oct 1, 2015 06:05 PM
GVMV
Aug 16, 2015 07:08 PM
92firebirdchris
Aug 14, 2015 11:56 AM
