85 firebird, will a 1990 iroc door fit?
Old Aug 14, 2013 | 04:32 PM
no green's Avatar
Hi guys,
The drivers door on my 85 firebird is shot, the hinges are wore out, the bottom has a rust hole in it, and the window regulator just went over the weekend (when i was trying to roll the window down, and get out in the trailer).... So i just want to replace the whole thing with a used one, ready to go.
I think i found a realy nice 1990 Iroc door localy for a good price. Will that fit? Someone told me once the body lines were not the same, but they bolted in place, i dont know if they were blowing smoke, though.
if it fits, and the body lines are right, what about the interior handles, and where the interior parts mount? window regulators the same?
Basicaly, can I bolt it on and go, or is it too much headache??
Thanks in advance.
Old Aug 14, 2013 | 04:47 PM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
Re: 85 firebird, will a 1990 iroc door fit?
I think it will be a bit different. I have a 90 iroc vert and the bastard door I have on driver side is much different.
#1 ground FX are different, I have a big gap at the front fender, and the molding doesnt line up. I am suspecting this door is from either a bird or an earlier year camaro. Wouldnt be surprised if bolt holes may have been slightly moved also.
I did pull it off and rebuilt the hinges .... pretty easy job, work out too -now closes nice.
Old Aug 14, 2013 | 05:01 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
All 82-92 3rd gen doors will interchange & are identical except for items on them, but the doors themselves will interchange.
Ground FX are obviously different between various doors but can be swapped. Interior panels are different but can be swapped. GTAs have a different arm rest that requires a different mount for them but that can be swapped too. Manual & power windows are diferent items but can be swapped out too.
But the basic doors themselves are identical.
Old Aug 14, 2013 | 06:37 PM
no green's Avatar
Thanks! That's what I wanted to hear.
I don't ground Fx, so that's not an issue.
Old Aug 14, 2013 | 06:47 PM
Joe Tag's Avatar
Iroc doors will have holes for the GFX you have to have welded up. Otherwise the same.
Old Aug 17, 2013 | 02:06 PM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
The only bad thing is that is the door that has your vehicle identification on it. I try to keep the original Dr door on all of my vehicles just in case the gov'ment has any questions.
Old Aug 17, 2013 | 05:27 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
its still under the windshield...
Old Aug 17, 2013 | 06:43 PM
Car: 1989 IROC
Engine: 305TPI
So you have never seen the DMV or Police or Emissions personal open the door to double check VIN?
Happens all the time around here
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
BlackTopKing
Aug 19, 2015 12:13 PM
mustangman65_79
Aug 11, 2015 03:17 PM
