hood wont raise evenly????
Old Oct 2, 2001 | 12:17 AM
Kandied91z's Avatar
when i had my hood removed for painting it was put back together with new struts, but it won't raise evenly......... it seems to line up with the body nicely and looks good when closed; but you definately have to put more pressure on one side then the other to raise it.
has anyone had this problem?
Old Oct 2, 2001 | 06:49 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Yup, same here. I have to put more pressure on the drivers side, but I have no idea why it does that either...sorry Anyone else??
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
Old Oct 2, 2001 | 06:51 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It's probably because one of the hinges is a bit tweaked. Loosen the 3 bolts, then retighten them and see if it helps.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 2, 2001 | 11:48 AM
Kandied91z's Avatar
I've tried adjusting them up and down every which way possible; but there is only so far you can go with out throwing off the angle of the hood!!
I don't understand because the hinges seemed to work perfect before they were coated now it doesn't
any other ideas?
Old Oct 2, 2001 | 10:13 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Are you sure the hood shocks are working properly. When my car was painted, the guy who painted it got a little bit of paint on one of the shocks. It screwed up the seal and leaked all the gas and oil out.
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Old Oct 2, 2001 | 10:31 PM
RODS92Z's Avatar
Mine did it too until I put new hood shocks in after I had the car painted.
1992 Camaro Z-28 custom 25th anniversary, 5.7 TPI auto, 2.73 posi, t-tops, arctic white with 92' medium mettalic gray stripes with black border stripe.
1967 Pontiac Catalina 2 door fastback, 400 v-8, auto, cameo white, dark red interior
1987 Olds Cutlass, 350 Rocket, auto, dark gray/light gray interior
http://camaroz28.cardomain.com/id/rods92z
Old Oct 2, 2001 | 11:48 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
My camaro started doing that after I put new struts on (having the hood jumped on didn't make it any better either). The drivers side pops easily & then the pass side jumps up after the drivers side gets to a certain height. One (more obvious now) suspicion on mine is the the underhood reinforcement seperating from the skin, since it's only glued on (except around the perimeter), letting the hood cross flex (or bow, whichever you want to call it) easily. My 'bird stopped doing that after getting a brand new hood.
Might not be the true problem, but since getting jumped on, & the reinforcement is hanging on by a thread, my camaro hood is worse than it was (and more rattly). It seems camaros might be a bit more prone to this because of the bracing & the square hood, but that's just my opinion, I could be wrong.
The mind is like a parachute, it only works when its open
Old Oct 3, 2001 | 12:37 AM
Kandied91z's Avatar
i suppose it could be the strut, it is brand new; but it could happen.........i know what you guys are describing, but this is a little different. I'll try to replace my strut again and see if that helps i guess.
Old Oct 3, 2001 | 01:41 PM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
i have the same problem, and i really dont think there is a cure to it, but i do know that when my struts were brand spankin new it went up evenly with no problem.
1987 LG4 Camaro z28
Performance
KN airfilter, flowmaster 80 series and catco high flow converter, 180* thermostat, edelbrock performer intake
System
Panasonic CQ-DF200U deck, fosgate speakers (hpc1369, frc2246), fosgate 400a4 amp
Old Oct 3, 2001 | 02:05 PM
87_Camaro's Avatar
my hood does the exact same thing driver side pops up first then the passegner catches up, i dotn really know if its the positioning of the hood or just the fact that my struts didnt work when i got the car so i had to throw on soem new ones, i think its just the hood
87 V6 2.8 MPFI Camaro SC
Modded dual snorkle intake "bottoms hacked off", K&N air filters, Crane Cams 8.5mm fire wire, Accel Cap and Rotor, MSD coil. upcoming mods:
Dynomax CatBack exaust system = VERY SOON
crane cams camp shaft, CC roller rockers, double timing chain
Old Oct 4, 2001 | 12:24 AM
Kandied91z's Avatar
all right.......... i bought new struts even though the ones were good and the problem isn't solved. any other suggestions
Old Oct 4, 2001 | 02:28 AM
EvilCartman's Avatar
Car: '82 Z28
lube up the hinges a bit and see if that helps.
Old Oct 5, 2001 | 07:37 AM
purpleworm's Avatar
Mine does that too.....my old 84 had no prob but the hood shockes where beat. I find that the hood on the 91 wobbles all the time and the hinges aren't really secure....I think it is the nature of my car.
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
