headlight upgrades
Old Sep 15, 2013 | 04:38 PM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
headlight upgrades
i want to start off and say i did search this subject and the information i found was outdated, with old links invalid parts number and such.
that being said, what is everyone doing to upgrade their headlights? i would be interested in just going with a composite headlight and just halogen bulbs or even HID upgrade.
let hear it people, what is everyone doing and where do you buy your lenses
Old Sep 15, 2013 | 09:51 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: headlight upgrades
E36 mod and got them on ebay. You could always buy the housings off ebay and then put HID's in them as alot of people do that as well
Old Sep 15, 2013 | 10:15 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I replaced the inner pair of hi-beam lights with a stock pair of outer hi/lo bulbs i pulled from the local U-Pull and replaced the 55w bulbs in my fog lights with a pair of 100w H3 bulbs. Then i wired in new relays to run the all the lights straight off the battery instead of through the headlight switch. Doubled my light output while keeping the stock look, all for less than $20.
Old Sep 16, 2013 | 04:24 AM
Mad Myche's Avatar
Car: 89 Camaro RS
Engine: 2.8 V6
Transmission: Automatic
I will be replacing the outer lamps on mine with quality H4 E-code lamps.
My manufacturer of choice is Cibie, but they no longer manufacture the 4x6 size. I wull not use Hella and none of the junk conversions that litter the internet
Talbotts still sells Cibies in 4x6 but I'm not paying their outrageous prices. Daniel Stern is selling Bosch lamps for this size as his supply is gone. I found one of my local suppliers still has them and many other quality brands of yesteryear such as Marchall. Once I get out by him I will take a look at what he has and refine my selection at that point.
I actually saw quite a few third gens over the weekend and at least 2 were not running oem lighting.
The first one was a projector retrofit that looked like it must of been sourced at the component level as the assemblies did not appear to look like they belonged in something else, and the lamps were all the way to the front of the housing.
The second one was some generic h4 clear assemblies stuffed with HIDs, Actually was able to see them in use, and was still unimpressed.
Old Sep 16, 2013 | 07:01 AM
cdoyle's Avatar
HID Projectors are the way to go, I got mine from the retrofitsource.
Old Sep 16, 2013 | 09:15 AM
86iroct5's Avatar
details please?
Old Sep 16, 2013 | 10:22 AM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Hawks sells a set for $150 or so. They're decent at best, very poor quality control, I had mine break twice already, they replaced them but I was ticketed once while I waited for the replacement.
Old Sep 16, 2013 | 12:50 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Sylvania Silver Stars,the Ultras might be to bright. The Silver Stars are true-white bulbs =
http://www.oreillyauto.com/site/c/de...1576&ppt=C0335
Old Sep 16, 2013 | 04:54 PM
knight72's Avatar
Car: 1992 W68 Firebird
Engine: 305 5.0L V8 TBI
replaced headlights and fogs with HIDs
Attached Thumbnails headlight upgrades-20130821_214136.jpg   headlight upgrades-20130824_204135.jpg
Old Sep 18, 2013 | 05:09 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Try classicgarage.com. They were recently selling NOS Cibie 4x6 H4/H1 conversions.
I bought the H1 Hi beams from them for ~$125/pair.
I had already scored set of H4 Hi/Lo's off of ebay.
Old Sep 18, 2013 | 06:07 PM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
Do yourself and your wallet a favor, spend a couple bucks the first time and buy the Autopal 4x6 headlamp housings, they are on ebay and I payed $50 for both housings last year. They come with H4's to use but I stepped up to HID's and will never look back. The best part is that the Autopal housings are E code approved(Europe) which satisfies DOT standards I.E. they are legal. Plus they focus the light just right with enough to light up signs but not blind anybody. Not to mention it's made from real glass lens and a real metal reflector.
If you buy one of those fake "projector" housings on ebay you'll be very sadly disappointed just like I was after wasting $35.
My .02 and from experience.
ALSO, one last note: If you do an H4 conversion you'll have to swap two wires in the headlight plug on the car, comes out very easy with a pocket screwdriver.
Old Sep 18, 2013 | 10:29 PM
Mad Myche's Avatar
Car: 89 Camaro RS
Engine: 2.8 V6
To the best of my knowledge the only standard that any of the h4 retrofit lamps have met is SAE-M as in motorcycle.
Will keep this in mind.... going to be checking out lamps next week
Old Sep 19, 2013 | 07:01 AM
cdoyle's Avatar
Originally Posted by 86iroct5
details please?
going with a true HID projector, you'll get the benefits of HID but not blind everyone else on the road. You can see in the picture I posted, how the cutoff are.
Here is another one that shows the cuttoff, notice there is now scattered light above the cutoff.
what I really love about mine, is they are a lo and high beam projector. When I put them in highbeam, there is a shield that moves up and it lights up everything. I can't believe how much improvement there is over the old stock lights.
Old Sep 19, 2013 | 05:01 PM
jpearcy1's Avatar
Car: '87 Iroc
Engine: 350 TPI with Holley Terminator X
Transmission: 4L60e
Axle/Gears: Stock/ Factory
Where did you get your set?
Old Sep 19, 2013 | 06:03 PM
Mad Myche's Avatar
Car: 89 Camaro RS
Engine: 2.8 V6
Way up at the top above is his first set of images
Old Sep 30, 2013 | 04:54 AM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
what housings did you guys use? all I can seem to find are the sketchy looking ebay-looking ones
Old Sep 30, 2013 | 11:04 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Tried the H4 kits, 3-4 different brands...all crap.Next sylvaina cool blues...slightly better, then silverstars...way better.Then sylvaina Xenarcs (later modified w/ Valeo projectors, below)
Old Sep 30, 2013 | 11:05 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
u gota hardon for sylvania don't you.
Old Sep 30, 2013 | 11:07 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
If it works, it works.
Old Sep 30, 2013 | 11:09 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
I'm looking to do HID's not just h4's
Old Sep 30, 2013 | 11:13 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
If you want the best output from HIDs, projectors are necessary & OEM projectors are the way to go.Not aftermarket with H4s adapted.
Old Sep 30, 2013 | 11:16 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
the **** is an oem projector, cuz they dont come on 3rd gens.
Old Sep 30, 2013 | 11:19 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
****? Well camaros were equiped with 4656 halogen lamps.Valeos are OEM in many cars (w/hid).
Old Sep 30, 2013 | 11:20 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
camaros are not my style. I prefer firebirds, so...
Old Sep 30, 2013 | 11:22 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Im sure you can find some here who has done a retrofit on a FB.Ive seen the post in the fabrication board.
Old Sep 30, 2013 | 11:23 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
whats the keyword. I've only seen one firebird on here with HID's and the guy didnt use projectors so they blind everyone
Old Sep 30, 2013 | 11:27 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
All i remember was some about making them non pop-up.I think maybe with miromoto projectors from the retrofit source.
Old Sep 30, 2013 | 11:29 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
I like the pop ups. because otherwise I have to wire in a bunch of daytime running ****
Old Sep 30, 2013 | 11:30 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Pretty sure the mod can be done w/out deleting the pop up.
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
I need a housing that I can actually take apart. that's what I'm asking for.
Old Sep 30, 2013 | 11:37 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Those cheap ebay fake projectors are what someone here used.Cant remember if it was the pop up delete or someone else, but its been done.Thats also what i used for my valeo retrofit, w/a 4656 though.
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
ugh. damn chinese crap
Old Sep 30, 2013 | 11:41 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Crap headlamp is what you want.If it fails your only out 20 some bucks.Your not using it for the reflector or lense.You just need it as a housing for the projector.
Old Sep 30, 2013 | 11:42 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
what projector do I want then
Old Sep 30, 2013 | 11:48 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thats up to personal preference, but the mirimoto seems to be compact enough to fit.I have the Hella E55 on my bike, but they're slightly larger.Just make sure its a bi xenon projector, because those are the ones with both hi/lo in one.Single xenon are what camaro guys should use.Check out HIDplanet.com, there is tons of info there.Thats where i got educated on HIDs.
Old Sep 30, 2013 | 11:54 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
another forum. damn I though it was just a page with info.
Old Sep 30, 2013 | 11:58 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Yeah, its a forum, but very good & useful info.Just browse, if you dont wanna join.
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
too lazy
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
Veaceonee
Sep 29, 2016 08:15 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
